Zum Hauptinhalt wechseln
Lenovo Tab S8 Battery Replacement
Was du brauchst
  1. Lenovo Tab S8 Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Lenovo Tab S8 Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Make sure the device is powered off.
    • Gently insert a spudger into one of the bottom corners between the screen and body case.
    • Slide the spudger along the inside of the crack in order to pry the case open.
    • Be careful of the small volume and power buttons when prying the case with the spudger. They are connected with small pieces of plastic that break easily.
  2. Lenovo Tab S8 Battery Replacement: Schritt 2, Bild 1 von 3 Lenovo Tab S8 Battery Replacement: Schritt 2, Bild 2 von 3 Lenovo Tab S8 Battery Replacement: Schritt 2, Bild 3 von 3
    • After removing the cover, remove the M1.6 x 2 mm screw from the battery cable with the JIS J000 screwdriver.
    • Using screwdriver bits that do not fit in the screw head might strip the screw and render it unusable.
    • Remove the tape by gently scraping the edges up with the spudger.
  3. Lenovo Tab S8 Battery Replacement: Schritt 3, Bild 1 von 3 Lenovo Tab S8 Battery Replacement: Schritt 3, Bild 2 von 3 Lenovo Tab S8 Battery Replacement: Schritt 3, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Plastic Cards
    $2.99
    Kaufen
    • Before removing the battery, be sure to disconnect the ribbon cables underneath it. The cables might stick to the battery during removal and cause damage.
    • Gently lift the flaps on the four ZIF connectors to disconnect the cables.
    • Use the plastic card to gently pry the battery from the device.
    • There may be glue holding the battery to the device. Use the spudger to detach any glue while the battery is partially raised by the card.
Abschluss
15 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team 3-6, Eyestone Fall 2015 Mitglied von USF Tampa, Team 3-6, Eyestone Fall 2015
USFT-EYESTONE-F15S3G6
3 Mitglieder
11 Anleitungen geschrieben
Ein Kommentar
Where we can buy battery
rithwik reddy gorripati - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 25
Letzte 30 Tage: 81
Insgesamt: 13,491
