Zum Hauptinhalt wechseln
Lenovo ThinkPad L440 Back Panel Replacement
Was du brauchst
  1. Lenovo ThinkPad L440 Back Panel Replacement, Battery: Schritt 1, Bild 1 von 3 Lenovo ThinkPad L440 Back Panel Replacement, Battery: Schritt 1, Bild 2 von 3 Lenovo ThinkPad L440 Back Panel Replacement, Battery: Schritt 1, Bild 3 von 3
    • Open the laptop to access the power button.
    • Hold the power button in the top right until the computer powers off.
    • Turn the computer over so that the bottom of the computer is facing up
  2. Lenovo ThinkPad L440 Back Panel Replacement: Schritt 2, Bild 1 von 1
    • On the left side under the raised surface, move the tab to the left towards the unlocked symbol. Repeat this on the right side and move the tab to the right towards the unlocked symbol.
  3. Lenovo ThinkPad L440 Back Panel Replacement: Schritt 3, Bild 1 von 2 Lenovo ThinkPad L440 Back Panel Replacement: Schritt 3, Bild 2 von 2
    • From the top of the laptop, slide the raised surface away from the rest of the laptop and out of its slot to remove the battery from the computer.
  4. Lenovo ThinkPad L440 Back Panel Replacement, Back Panel: Schritt 4, Bild 1 von 2 Lenovo ThinkPad L440 Back Panel Replacement, Back Panel: Schritt 4, Bild 2 von 2
    • Loosen the four retainer screws on the bottom of the laptop using a Phillips #0 screwdriver.
    • These four screws are attached to the panel with washers, so they will spin freely when they are loose and will come off with the panel.
  5. Lenovo ThinkPad L440 Back Panel Replacement: Schritt 5, Bild 1 von 2 Lenovo ThinkPad L440 Back Panel Replacement: Schritt 5, Bild 2 von 2
    • With your fingers, lift up the back panel from the left side.
Abschluss
Kristen Gismondi
92.603 Reputation
241 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
118 Mitglieder
19.636 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 18
Letzte 30 Tage: 43
Insgesamt: 66
