Zum Hauptinhalt wechseln
Lenovo ThinkPad T431S Battery Replacement
Was du brauchst
  1. Lenovo ThinkPad T431S Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Lenovo ThinkPad T431S Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Remember, to prevent electric shock or harm, disconnect the laptop from any external power source and make sure device is powered off before starting any disassembly.
    • Use a Phillips #1 screwdriver bit to remove the eight 5mm screws from the back panel.
    • Once the screws are loose, use the three opening tools to loosen and remove the back panel.
  2. Lenovo ThinkPad T431S Battery Replacement: Schritt 2, Bild 1 von 3 Lenovo ThinkPad T431S Battery Replacement: Schritt 2, Bild 2 von 3 Lenovo ThinkPad T431S Battery Replacement: Schritt 2, Bild 3 von 3
    • Carefully unplug the battery cable from the connector on the motherboard, using your fingers to pull the cable straight out of the port.
  3. Lenovo ThinkPad T431S Battery Replacement: Schritt 3, Bild 1 von 3 Lenovo ThinkPad T431S Battery Replacement: Schritt 3, Bild 2 von 3 Lenovo ThinkPad T431S Battery Replacement: Schritt 3, Bild 3 von 3
    • Unscrew the five 4mm screws that are holding the battery secure with a Phillips #1 screwdriver.
    • Remove the Li-polymer battery by lifting it directly out of the device.
    • Information about disposal of your damaged battery can be found at E-Waste Recycling
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 16
Insgesamt: 1,219
