Zum Hauptinhalt wechseln
Lenovo ThinkPad T580 Wi-Fi Card Replacement
Was du brauchst
  1. Lenovo ThinkPad T580 Wi-Fi Card Replacement, External Battery: Schritt 1, Bild 1 von 3 Lenovo ThinkPad T580 Wi-Fi Card Replacement, External Battery: Schritt 1, Bild 2 von 3 Lenovo ThinkPad T580 Wi-Fi Card Replacement, External Battery: Schritt 1, Bild 3 von 3
    • Slide the switch on the left side of the battery to the left.
  2. Lenovo ThinkPad T580 Wi-Fi Card Replacement: Schritt 2, Bild 1 von 3 Lenovo ThinkPad T580 Wi-Fi Card Replacement: Schritt 2, Bild 2 von 3 Lenovo ThinkPad T580 Wi-Fi Card Replacement: Schritt 2, Bild 3 von 3
    • Slide the switch on the right side of the battery to the right while applying upward pressure on the battery.
  3. Lenovo ThinkPad T580 Wi-Fi Card Replacement: Schritt 3, Bild 1 von 3 Lenovo ThinkPad T580 Wi-Fi Card Replacement: Schritt 3, Bild 2 von 3 Lenovo ThinkPad T580 Wi-Fi Card Replacement: Schritt 3, Bild 3 von 3
    • Pull the battery directly out of the socket
  4. Lenovo ThinkPad T580 Wi-Fi Card Replacement, Bottom Case: Schritt 4, Bild 1 von 2 Lenovo ThinkPad T580 Wi-Fi Card Replacement, Bottom Case: Schritt 4, Bild 2 von 2
    • Using a Phillips #00 screwdriver, unscrew the eight 3.3 mm captive screws on the bottom of the laptop.
    • The "captive" screws will not come out of the case.
  5. Lenovo ThinkPad T580 Wi-Fi Card Replacement: Schritt 5, Bild 1 von 3 Lenovo ThinkPad T580 Wi-Fi Card Replacement: Schritt 5, Bild 2 von 3 Lenovo ThinkPad T580 Wi-Fi Card Replacement: Schritt 5, Bild 3 von 3
    • Run a Jimmy along the crease of the computer all the way around, twisting it periodically to disengage the clips.
  6. Lenovo ThinkPad T580 Wi-Fi Card Replacement: Schritt 6, Bild 1 von 3 Lenovo ThinkPad T580 Wi-Fi Card Replacement: Schritt 6, Bild 2 von 3 Lenovo ThinkPad T580 Wi-Fi Card Replacement: Schritt 6, Bild 3 von 3
    • Once all the clips are released, remove the bottom cover.
    • You may need to jiggle the case slightly to release the clips around the external battery bay.
  7. Lenovo ThinkPad T580 Wi-Fi Card Replacement, Internal Battery: Schritt 7, Bild 1 von 1
    • Using a Phillips #00 screwdriver, remove five 3.7 mm screws holding down the battery.
  8. Lenovo ThinkPad T580 Wi-Fi Card Replacement: Schritt 8, Bild 1 von 3 Lenovo ThinkPad T580 Wi-Fi Card Replacement: Schritt 8, Bild 2 von 3 Lenovo ThinkPad T580 Wi-Fi Card Replacement: Schritt 8, Bild 3 von 3
    • Unplug and remove the battery connector from the motherboard.
    • Remove the internal battery.
  9. Lenovo ThinkPad T580 Wi-Fi Card Replacement, Wi-Fi Card: Schritt 9, Bild 1 von 3 Lenovo ThinkPad T580 Wi-Fi Card Replacement, Wi-Fi Card: Schritt 9, Bild 2 von 3 Lenovo ThinkPad T580 Wi-Fi Card Replacement, Wi-Fi Card: Schritt 9, Bild 3 von 3
    • Using a spudger, pop off the gray and black coaxial cables from the Wi-Fi card.
  10. Lenovo ThinkPad T580 Wi-Fi Card Replacement: Schritt 10, Bild 1 von 3 Lenovo ThinkPad T580 Wi-Fi Card Replacement: Schritt 10, Bild 2 von 3 Lenovo ThinkPad T580 Wi-Fi Card Replacement: Schritt 10, Bild 3 von 3
    • Using a Phillips #00 screwdriver, remove the 3.6 mm screw from the Wi-Fi card.
  11. Lenovo ThinkPad T580 Wi-Fi Card Replacement: Schritt 11, Bild 1 von 3 Lenovo ThinkPad T580 Wi-Fi Card Replacement: Schritt 11, Bild 2 von 3 Lenovo ThinkPad T580 Wi-Fi Card Replacement: Schritt 11, Bild 3 von 3
    • Slide the Wi-Fi card out from the socket on the motherboard.
Abschluss
Austin Blakely
19.855 Reputation
53 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
141 Mitglieder
17.895 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 888
