Zum Hauptinhalt wechseln
Lenovo ThinkPad X1 Carbon (2nd Gen) Battery Replacement
Was du brauchst
  1. Lenovo ThinkPad X1 Carbon (2nd Gen) Battery Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Using a Phillips #0 screwdriver, remove the seven 7mm screws holding the back cover onto your computer.
  2. Lenovo ThinkPad X1 Carbon (2nd Gen) Battery Replacement: Schritt 2, Bild 1 von 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Battery Replacement: Schritt 2, Bild 2 von 2
    • Use a plastic opening tool or your fingers to pry off the cover.
  3. Lenovo ThinkPad X1 Carbon (2nd Gen) Battery Replacement, Battery: Schritt 3, Bild 1 von 2 Lenovo ThinkPad X1 Carbon (2nd Gen) Battery Replacement, Battery: Schritt 3, Bild 2 von 2
    • Using your fingers, disconnect the battery from the motherboard.
  4. Lenovo ThinkPad X1 Carbon (2nd Gen) Battery Replacement: Schritt 4, Bild 1 von 1
    • Using a Phillips #0 screwdriver, unscrew the five 4.3mm screws attaching the battery to the computer.
  5. Lenovo ThinkPad X1 Carbon (2nd Gen) Battery Replacement: Schritt 5, Bild 1 von 1
    • Remove the battery by pulling it directly towards you.
Abschluss
9 weitere Personen haben diese Anleitung absolviert.
Eevee Murdock
1.110 Reputation
6 Anleitungen geschrieben
Cal Poly, Team S18-G4, White Winter 2020 Mitglied von Cal Poly, Team S18-G4, White Winter 2020
CPSU-WHITE-W20S18G4
4 Mitglieder
9 Anleitungen geschrieben
4 Kommentare
iFixit replacement battery is rejected by X1 Carbon gen2 chassis as not-genuine/unauthorized. Is there some additional step to getting the battery to be recognized/allowed? Something in the BIOS? Or is the battery faulty?
lenovo_battery - Antwort
Any comments from @ifixit?
Martin Optilon - Antwort
Hi there! Thanks for bringing this to our attention. @lenovo_battery, sorry to hear you're having trouble with your battery. Please reach out directly to our customer support team by emailing support@ifixit.com.
Kristen Gismondi -
Hi,
Great guide. I found that my screw heads were a bit stripped and the #0 driver was too small and bounced too much. The #1 driver worked better for me. Thanks for promoting the repair revolution! - MiLo
milostudios - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 27
Letzte 30 Tage: 85
Insgesamt: 5,750
