Was du brauchst
Flip the laptop over so the bottom is facing you.
Remove the ten screws using a Phillips #1 screwdriver.
Using the plastic opening tool, pry the bottom cover off the laptop.
Remove two screws from the battery using a Phillips #1 screwdriver.
Disconnect the battery connector from the motherboard.
Remove the battery from the laptop.
Remove two screws holding the Wi-Fi card in place using a Phillips #1 screwdriver.
Pull the Wi-Fi card gently in the opposite direction of the connector to remove it from the laptop.
