Was du brauchst
Flip your laptop over and place on a flat surface so you can access the screws on the base cover.
Remove the six 7 mm screws from the back panel of the laptop using a Phillips #0 screwdriver.
Remove the four 4 mm screws from the bottom edge of the laptop using a Phillips #0 screwdriver.
Use an iFixit opening tool to pry apart the case by sliding it along each side of the laptop.
Fast fertig!
Abschluss
