Was du brauchst
Flip your laptop over and place on a flat surface so you can access the screws on the base cover.
Remove the six 7 mm screws from the back panel of the laptop using a Phillips #0 screwdriver.
Remove the four 4 mm screws from the bottom edge of the laptop using a Phillips #0 screwdriver.
Use an iFixit opening tool to pry apart the case by sliding it along each side of the laptop.
Using a Phillips #0 screwdriver, remove the four 5 mm screws from the hinges of the laptop.
Using the spudger, disconnect the two wireless LAN cables (black and gray) from the wireless LAN card.
Remove the LAN cables from the three brackets on the fan.
