Zum Hauptinhalt wechseln
Lenovo YOGA 730-15IWL Battery Replacement
Was du brauchst
  1. Lenovo YOGA 730-15IWL Battery Replacement, Remove the base cover screws: Schritt 1, Bild 1 von 1
    • Remove the screws (M2.0 x 7.0 mm, Torx).
  2. Lenovo YOGA 730-15IWL Battery Replacement, Remove the base cover: Schritt 2, Bild 1 von 1
    • Remove the base cover. Consider using a spudger.
  3. Lenovo YOGA 730-15IWL Battery Replacement, Remove the battery: Schritt 3, Bild 1 von 1
    • Unplug the battery connector in the direction shown by arrow
    • Remove the screws (M2.0 x 4.5 mm).
    • Remove the battery pack.
Abschluss
To replace the battery & reassemble your device, follow these instructions in reverse order.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Max Kletskov
40.298 Reputation
16 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
135 Mitglieder
17.163 Anleitungen geschrieben
2 Kommentare
My issue with my Lenovo Yoga 730-15 laptop was not the battery I just successfully replaced. It still does not turn on. The Power button light up for a short time when pressed to power up the laptop. However, it then goes out and the laptop does not startup. Any Ideas?? Thanks
Al Cross - Antwort
Check thermal paste. May be getting hot and shutting back off.
William Mobley - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 12
Letzte 30 Tage: 41
Insgesamt: 1,358
