Einleitung
Is your laptop's trackpad not reacting when you use it? Then you will probably need to replace it and this guide will help you accomplish the task!
Was du brauchst
Remove the eleven 6 mm T5 Torx screws securing the lower case.
Gently lift the lower case up and away from the device.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Use a pair of tweezers to gently disconnect the battery connector.
Use a pair of tweezers to gently disconnect the speaker cable.
Remove the wires from underneath the battery tabs using the tweezers.
Use the tweezers to partially remove the tape.
Use a pair of tweezers to disconnect the ZIF connector securing the trackpad ribbon cable. Gently lift up the black tab and the ribbon cable should come free.
Eine weitere Person hat diese Anleitung absolviert.
1 Kommentar zur Anleitung
Very brief, great illustrations. Now, I need to try it.
