Einleitung
Use this guide to replace the bottom camera in your Lenovo Yoga Book X90F.
The Lenovo Yoga Book X90F comes with two cameras, one on the top screen and one on the bottom. The bottom camera is used when the computer is in Tablet mode.
Before considering replacing the camera, check out the Lenovo Yoga Book X90F troubleshooting page.
Replacing the camera requires the removal of the bottom screen. This process will end up with you needing to also replace the screen. Be careful as sharp glass can become a problem if the screen shatters.
Was du brauchst
Turn off and power down the device before beginning this process. A heat gun or hair dryer will be suitable to heat the adhesive that holds down the screen. Apply heat to the entire surface area of the bottom screen.
Once the adhesive has been heated up, take the iFixIt suction cup and lift in a corner. The screen should be separating from the adhesive here.
While the screen is lifted, insert the ifixit opening pick to help pry off the screen.
While the screen has been lifted, insert the plastic opening picks. Heat the adhesive and follow with the screen removal tool to ensure that you are not prying it apart with excessive force.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
After the screen has been opened, disconnect the ribbon connecting the bottom screen to the motherboard by gently pulling the ribbon with tweezers.
If there are black coverings on the tabs as shown in the second image, carefully remove them using a pair of tweezers.
Use the spudger to remove the yellow sticker from the motherboard.
Remove the camera's orange ribbon connector tab.
Use the spudger to get under the orange tab and lightly pull upwards.
Use the a pair of tweezers to remove the ribbon.
Use the pointed end of the spudger to pry out the camera.
Pull out the camera with tweezers.
