Einleitung
This guide includes all the steps, tools, and parts necessary to disassemble the Lenovo Yoga C930-13IKB to access and replace the power button board.
Was du brauchst
Flip the device over so that the underside is facing up.
Remove the six 3.5 mm T5 Torx screws.
Pry off the back cover using the plastic opening tool.
Loosen the back cover in multiple spots using the opening tool, then remove the whole back.
Unplug the battery from the motherboard by pinching the cables with your fingers and tugging out with force.
Use your fingers to pry up the clear plastic pull-tab for one of the stretch release adhesives.
Grasp the pull-tab and slowly pull away from the battery at a shallow angle. The adhesive strip will stretch to many times its length and slowly release from underneath the battery.
Repeat the procedure for the second strip on the opposite side of the battery.
Remove the battery with your hands.
Remove the screw ( 2 mm with a 5 mm head) that connect the SSD to the motherboard using a Phillips #00 screwdriver.
Pinch the left side of the SSD card.
Pull gently to the left, horizontal to the laptop.
Unscrew the two 2mm screws using a Phillips #00 screwdriver.
Gently lift out the digital pen spring using the iFixit opening tool.
Remove four 2 mm screws from the digital pen holder using a Phillips #00 screwdriver.
Carefully lift out the digital pen holder with the attached power button ribbon cable.
Depress the power button, then gently pull and detach it using the angled ESD tweezers.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
