Zum Hauptinhalt wechseln
Lenovo Yoga C930-13IKB Speaker Replacement
Was du brauchst
  1. Lenovo Yoga C930-13IKB Speaker Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Flip the device over so that the underside is facing up.
    • Remove the six 3.5 mm T5 Torx screws.
  2. Lenovo Yoga C930-13IKB Speaker Replacement: Schritt 2, Bild 1 von 2 Lenovo Yoga C930-13IKB Speaker Replacement: Schritt 2, Bild 2 von 2
    • Pry off the back cover using the plastic opening tool.
    • Loosen the back cover in multiple spots using the opening tool, then remove the whole back.
    • You may have to run the plastic tool along the edges until you find a small gap to separate the back cover from the laptop.
    • Do not use a metal tool when working with your device.
  3. Lenovo Yoga C930-13IKB Speaker Replacement: Schritt 3, Bild 1 von 2 Lenovo Yoga C930-13IKB Speaker Replacement: Schritt 3, Bild 2 von 2
    • Carefully lift the cover off with your hands.
  4. Lenovo Yoga C930-13IKB Speaker Replacement, Battery: Schritt 4, Bild 1 von 3 Lenovo Yoga C930-13IKB Speaker Replacement, Battery: Schritt 4, Bild 2 von 3 Lenovo Yoga C930-13IKB Speaker Replacement, Battery: Schritt 4, Bild 3 von 3
    • Unplug the battery from the motherboard by pinching the cables with your fingers and tugging out with force.
    • Use the spudger for assistance.
  5. Lenovo Yoga C930-13IKB Speaker Replacement: Schritt 5, Bild 1 von 1
    • Unscrew the four 3mm screws with a Phillips screwdriver.
  6. Lenovo Yoga C930-13IKB Speaker Replacement: Schritt 6, Bild 1 von 2 Lenovo Yoga C930-13IKB Speaker Replacement: Schritt 6, Bild 2 von 2
    • The battery is still held in place with two stretch-release adhesive strips, similar to ones found in an iPhone.
    • Use your fingers to pry up the clear plastic pull-tab for one of the stretch release adhesives.
    • Grasp the pull-tab and slowly pull away from the battery at a shallow angle. The adhesive strip will stretch to many times its length and slowly release from underneath the battery.
    • Repeat the procedure for the second strip on the opposite side of the battery.
    • Be careful not to bend the battery. Breaking the battery is dangerous.
    • Remove the battery with your hands.
  7. Lenovo Yoga C930-13IKB Speaker Replacement, Speakers: Schritt 7, Bild 1 von 2 Lenovo Yoga C930-13IKB Speaker Replacement, Speakers: Schritt 7, Bild 2 von 2
    • Remove the four 2mm screws that attach the speakers to the laptop body using a Phillips #00 screwdriver.
  8. Lenovo Yoga C930-13IKB Speaker Replacement: Schritt 8, Bild 1 von 3 Lenovo Yoga C930-13IKB Speaker Replacement: Schritt 8, Bild 2 von 3 Lenovo Yoga C930-13IKB Speaker Replacement: Schritt 8, Bild 3 von 3
    • Gently unplug the connector using two fingers.
    • Use an opening tool if needed.
  9. Lenovo Yoga C930-13IKB Speaker Replacement: Schritt 9, Bild 1 von 2 Lenovo Yoga C930-13IKB Speaker Replacement: Schritt 9, Bild 2 von 2
    • Lift the black wire that connects the speakers to the motherboard from its track using an opening tool.
    • Press the wire down firmly and in the right track when reassembling.
  10. Lenovo Yoga C930-13IKB Speaker Replacement: Schritt 10, Bild 1 von 2 Lenovo Yoga C930-13IKB Speaker Replacement: Schritt 10, Bild 2 von 2
    • Remove the right speaker using your fingers.
    • Remove the left speaker, which is connected to the right speaker by the black and red wire.
    • When reassembling, make sure the black and red wire is in the right track so that you are able to put the back cover back without wire poking out.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team S19-G5, White Winter 2020 Mitglied von Cal Poly, Team S19-G5, White Winter 2020
CPSU-WHITE-W20S19G5
4 Mitglieder
16 Anleitungen geschrieben
1 Kommentar zur Anleitung
What would be the additional steps to replace a right hinge as the speakers are in the hinge?
Brian Dernbach - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 52
Insgesamt: 1,219
