Einleitung
If you are having trouble with your Lenovo Yoga C930-13IKB touch pad or your touch pad is damaged, this guide will help you replace it. First, check out this troubleshooting guide to try other ways to fix a faulty touch pad before replacing it.
To access the touch pad, you will need to remove the back cover and the battery, which is outlined below. Then the back of the touch pad will be exposed and you can take it out once all the fasteners have been removed.
Ersatzteile
Keine Ersatzteile angegeben.
Flip the device over so that the underside is facing up.
Remove the six 3.5 mm T5 Torx screws.
Pry off the back cover using the plastic opening tool.
Loosen the back cover in multiple spots using the opening tool, then remove the whole back.
Unplug the battery from the motherboard by pinching the cables with your fingers and tugging out with force.
Use an opening tool underneath the battery to pry off the adhesive strips that keep the battery in place.
Remove the battery with your hands.
Ein weiterer Nutzer hat diese Anleitung absolviert.
