Zum Hauptinhalt wechseln
Lens Replacement
Was du brauchst
  1. Lens Replacement, Removing the Battery: Schritt 1, Bild 1 von 3 Lens Replacement, Removing the Battery: Schritt 1, Bild 2 von 3 Lens Replacement, Removing the Battery: Schritt 1, Bild 3 von 3
    • Flip the small blue switch up to release the battery. Remove the battery.
    • Remove two Philips #000 screws. Place the screws on a magnetic pad or somewhere safe.
    • Insert a plastic opening tool in the corner by the Micro USB plug. This area will allow leverage in order to take off the outer case.
  2. Lens Replacement, Removing the Outer Casing: Schritt 2, Bild 1 von 3 Lens Replacement, Removing the Outer Casing: Schritt 2, Bild 2 von 3 Lens Replacement, Removing the Outer Casing: Schritt 2, Bild 3 von 3
    • Use the opening tool and your fingers to pry apart the outer case. Hold back camera as well as menu navigation buttons while you remove the case.
    • Unscrew two small Phillips screws holding the outer case to the motherboard. Use the opening tool to unhook the case from the plate covering the motherboard.
    • The second screw (top left) is under the control PCB. The PCB is mounted to a metal plate that is retained by some adhesive tape underneath and two prongs (bottom-left). You need to pry the plate from the top-right until the tape is broken, then slide the plate upwards (relative to photo). Take care not to pull or tear the ribbon cable.
  3. Lens Replacement, Removing the Ribbon: Schritt 3, Bild 1 von 2 Lens Replacement, Removing the Ribbon: Schritt 3, Bild 2 von 2
    • Disconnect the button casing ribbon cable from the motherboard.
    • Be gentle when removing the ribbon.
    • Lift up the metal casing with one hand and use the other hand to snap the ZIF connector back, in order to remove the display ribbon cable.
  4. Lens Replacement, Replacing the Lens: Schritt 4, Bild 1 von 3 Lens Replacement, Replacing the Lens: Schritt 4, Bild 2 von 3 Lens Replacement, Replacing the Lens: Schritt 4, Bild 3 von 3
    • Remove the display and buttons.
    • Release the clamp on the two ribbon cables connected to the camera lens.
    • Be gentle when removing the ribbons cables. They are fragile and can tear.
    • Pull the lens out of the camera base.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
salome datong
104 Reputation
1 Anleitung geschrieben
USF Tampa, Team 14-4, Eyestone Fall 2016 Mitglied von USF Tampa, Team 14-4, Eyestone Fall 2016
USFT-EYESTONE-F16S14G4
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 12
Letzte 30 Tage: 28
Insgesamt: 1,044
