Zum Hauptinhalt wechseln
LexiBook Tablet One Battery Replacement
Was du brauchst
  1. LexiBook Tablet One Battery Replacement, Battery: Schritt 1, Bild 1 von 3 LexiBook Tablet One Battery Replacement, Battery: Schritt 1, Bild 2 von 3 LexiBook Tablet One Battery Replacement, Battery: Schritt 1, Bild 3 von 3
    • First the case must be opened. Insert the blue plastic opening tool where the two casings meet. Pry up until you hear a clip pop and then carefully move around the device. Do this until the front and back casing are completely separate from one another.
    • You will again need to be careful opening the device in order to avoid damaging the speaker, or worse, the motherboard.
    • The clips holding the case together are roughly 1.5 in. apart.
  2. LexiBook Tablet One Battery Replacement: Schritt 2, Bild 1 von 2 LexiBook Tablet One Battery Replacement: Schritt 2, Bild 2 von 2
    • Carefully remove the speaker by inserting the spudger between the case and the speaker. Pry upwards until the speaker comes out. Set the speaker to the side.
    • Be careful with the speaker wires. The wires can easily detach from both the speaker and the board.
  3. LexiBook Tablet One Battery Replacement: Schritt 3, Bild 1 von 1
    • Use the spudger to repeatedly gouge between the battery and LCD. Work around the battery until it breaks free.
    • It may feel as though you are pushing extremely hard. This is normal as the adhesive is quite strong. As long as you don't tip the tool you use and puncture the battery / LCD it will be fine.
  4. LexiBook Tablet One Battery Replacement: Schritt 4, Bild 1 von 2 LexiBook Tablet One Battery Replacement: Schritt 4, Bild 2 von 2
    • The tape around the battery's circuit board is extremely thorough. There are 2 pieces of tape, on folded over the side and another wrapped around the circuit board. Simply peel both off.
  5. LexiBook Tablet One Battery Replacement: Schritt 5, Bild 1 von 2 LexiBook Tablet One Battery Replacement: Schritt 5, Bild 2 von 2
    • Now that the battery is pry'd free and the tape is removed, the wires should be able to move freely. Give yourself as much room as you need, and solder off the connections on the motherboard.
    • How to Solder is iFixit's official guide to use a soldering gun.
Abschluss
Jordan
645 Reputation
4 Anleitungen geschrieben
Colorado Springs, Team 2-5, Panko Spring 2015 Mitglied von Colorado Springs, Team 2-5, Panko Spring 2015
UCCS-PANKO-S15S2G5
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 14
Insgesamt: 1,526
