Zum Hauptinhalt wechseln
Lexibook Junior Tablet Camera Replacement
Was du brauchst
  1. Lexibook Junior Tablet Camera Replacement, Battery: Schritt 1, Bild 1 von 1
    • Make sure your device is powered off before replacement to prevent electric shock.
    • With the device screen face down, use the metal spudger to remove the small rubber circles on all four corners of the device. The screws should now be revealed.
    • Using the metal spudger, pry open the small, long rubber rectangle on the back of the device to reveal more screws.
  2. Lexibook Junior Tablet Camera Replacement: Schritt 2, Bild 1 von 1
    • Using a Phillips #00 screwdriver, remove the four 6.8mm screws from the four corners of the device.
    • Using the same screwdriver, remove the three screws that were behind the rubber rectangle. These screws do not come out of the device.
    • Use the plastic opening tool to gently pry open the back panel of the tablet.
  3. Lexibook Junior Tablet Camera Replacement: Schritt 3, Bild 1 von 1
    • Use the nylon spudger to gently pry under the battery to remove it.
    • Make sure you do not damage the battery or metal plate in this process and only use a nylon spudger. Be patient and work slowly for the best results.
  4. Lexibook Junior Tablet Camera Replacement: Schritt 4, Bild 1 von 1
    • Use a soldering iron to remove the battery from the motherboard safely.
    • For advice on how to solder, check out iFixit's Soldering Guide.
  5. Lexibook Junior Tablet Camera Replacement, Motherboard: Schritt 5, Bild 1 von 2 Lexibook Junior Tablet Camera Replacement, Motherboard: Schritt 5, Bild 2 von 2
    • Using the plastic opening tool, gently push the two small, black and white switches out in the direction of the ribbon wires.
    • Slowly pull the ribbon wire out of the switch to free it.
  6. Lexibook Junior Tablet Camera Replacement: Schritt 6, Bild 1 von 1
    • Push the larger black and white strip leading to a ribbon wire upward using the plastic opening tool.
    • Carefully pull the ribbon wire out of the switch
  7. Lexibook Junior Tablet Camera Replacement: Schritt 7, Bild 1 von 3 Lexibook Junior Tablet Camera Replacement: Schritt 7, Bild 2 von 3 Lexibook Junior Tablet Camera Replacement: Schritt 7, Bild 3 von 3
    • Unscrew the five 4 mm screws around the perimeter of the motherboard using the ph00 size phillips head screwdriver.
  8. Lexibook Junior Tablet Camera Replacement: Schritt 8, Bild 1 von 2 Lexibook Junior Tablet Camera Replacement: Schritt 8, Bild 2 von 2
    • Remove the button board by unscrewing two more 4 mm screws and one 6.5 mm screw
  9. Lexibook Junior Tablet Camera Replacement: Schritt 9, Bild 1 von 1
    • Solder off connections from the wire connecting the motherboard to the speaker.
    • For how to solder, check out iFixit's Soldering Guide.
  10. Lexibook Junior Tablet Camera Replacement, Camera: Schritt 10, Bild 1 von 1
    • Using the plastic opening tool, pop up the black and white clip holding the ribbon wire in place for the camera.
    • This black and white clip removes in the same way that the large clip on the motherboard does.
  11. Lexibook Junior Tablet Camera Replacement: Schritt 11, Bild 1 von 1
    • Gently slide out the ribbon wire connecting the camera to the motherboard.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Rachel Klesius
645 Reputation
6 Anleitungen geschrieben
USF Tampa, Team 17-3, Blackwell Fall 2016 Mitglied von USF Tampa, Team 17-3, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G3
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 145
