Zum Hauptinhalt wechseln
Lexibook Junior Tablet Speaker Replacement
Was du brauchst
  1. Lexibook Junior Tablet Speaker Replacement, Battery: Schritt 1, Bild 1 von 1
    • Make sure your device is powered off before replacement to prevent electric shock.
    • With the device screen face down, use the metal spudger to remove the small rubber circles on all four corners of the device. The screws should now be revealed.
    • Using the metal spudger, pry open the small, long rubber rectangle on the back of the device to reveal more screws.
  2. Lexibook Junior Tablet Speaker Replacement: Schritt 2, Bild 1 von 1
    • Using a Phillips #00 screwdriver, remove the four 6.8mm screws from the four corners of the device.
    • Using the same screwdriver, remove the three screws that were behind the rubber rectangle. These screws do not come out of the device.
    • Use the plastic opening tool to gently pry open the back panel of the tablet.
  3. Lexibook Junior Tablet Speaker Replacement: Schritt 3, Bild 1 von 1
    • Use the nylon spudger to gently pry under the battery to remove it.
    • Make sure you do not damage the battery or metal plate in this process and only use a nylon spudger. Be patient and work slowly for the best results.
  4. Lexibook Junior Tablet Speaker Replacement: Schritt 4, Bild 1 von 1
    • Use a soldering iron to remove the battery from the motherboard safely.
    • For advice on how to solder, check out iFixit's Soldering Guide.
  5. Lexibook Junior Tablet Speaker Replacement, Speaker: Schritt 5, Bild 1 von 2 Lexibook Junior Tablet Speaker Replacement, Speaker: Schritt 5, Bild 2 von 2
    • Using the plastic opening tool, gently pry the speaker out of its plastic housing.
  6. Lexibook Junior Tablet Speaker Replacement: Schritt 6, Bild 1 von 1
Abschluss
Rachel Klesius
645 Reputation
6 Anleitungen geschrieben
USF Tampa, Team 17-3, Blackwell Fall 2016 Mitglied von USF Tampa, Team 17-3, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G3
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 15
Insgesamt: 180
