Einleitung
After the top casing is removed we can remove the bottom casing to isolate the motherboard.
Was du brauchst
Remove the antennas from the back of the device. To do this, follow steps 1 and 2 of Installing the Antennas Guide: Linksys WAP54g Antennas Replacement
Remove the two black rubber feet of the device using the screwdriver. The feet are located on the bottom towards the front.
Once the feet are removed, two small screws will be visible. With a small screwdriver, unscrew them. Screws are phillips head, 4.35 mm in diameter, 7.88 mm in length.
To remove the front blue panel, grip firmly and place thumbs in the two notches on top. Push thumbs forward while keeping a firm grip on bottom.
Now slide the bottom panel forward and remove it so the top casing is isolated from the bottom casing and motherboard.
Unscrew the nut on the outer side of the back casing. Remove the nut and the washer from both antenna mounts.
From here, remove the wires and nuts connected to the back panel by pulling the nuts through the holes.
Now the top casing has been removed and isolated from the rest of the device. From here, you can make repairs to the top casing.
Unscrew the two screws that connect the motherboard to the bottom casing.
After the motherboard is isolated component level repairs can be made.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
