Zum Hauptinhalt wechseln
Logic Board Disconnection
Grundständige Anleitung
Dies ist eine grundständige Anleitung, die nur als Teil einer anderen Anleitung verwendet werden sollte.
Was du brauchst
  1. Logic Board Disconnection, Disconnect the logic board: Schritt 1, Bild 1 von 2 Logic Board Disconnection, Disconnect the logic board: Schritt 1, Bild 2 von 2
    • Use a T3 Torx driver to remove the two 1.4 mm screws securing the trackpad connector bracket.
    • Depending on the condition of your bits, a T4 Torx driver may fit better.
    • Remove the trackpad connector bracket.
  2. Logic Board Disconnection: Schritt 2, Bild 1 von 2 Logic Board Disconnection: Schritt 2, Bild 2 von 2
    • Use the flat end of a spudger to pry the trackpad cable connector up and out of its socket.
  3. Logic Board Disconnection: Schritt 3, Bild 1 von 3 Logic Board Disconnection: Schritt 3, Bild 2 von 3 Logic Board Disconnection: Schritt 3, Bild 3 von 3
    • If the left speaker is already disconnected, skip this step.
    • Slide the tip of a spudger underneath the left speaker cable and pry straight up to disconnect the speaker.
    • With the connector disconnected, slide the flat end of a spudger under the cable to separate the adhesive securing the cable to the logic board.
  4. Logic Board Disconnection: Schritt 4, Bild 1 von 2 Logic Board Disconnection: Schritt 4, Bild 2 von 2
    • Use a T3 Torx driver to remove the two 1.3 mm screws securing the USB-C port connector bracket.
    • Remove the USB-C connector bracket.
  5. Logic Board Disconnection: Schritt 5, Bild 1 von 2 Logic Board Disconnection: Schritt 5, Bild 2 von 2
    • Use the flat end of a spudger to pry the USB-C cable connector up and out of its socket on the logic board.
  6. Logic Board Disconnection: Schritt 6, Bild 1 von 3 Logic Board Disconnection: Schritt 6, Bild 2 von 3 Logic Board Disconnection: Schritt 6, Bild 3 von 3
    • Use a spudger to lift up the small locking flap on the sound board cable's ZIF connector.
    • Slide the sound board cable out of the ZIF connector.
  7. Logic Board Disconnection: Schritt 7, Bild 1 von 1
    • Peel back the black tape covering the fan cable connector.
  8. Logic Board Disconnection: Schritt 8, Bild 1 von 3 Logic Board Disconnection: Schritt 8, Bild 2 von 3 Logic Board Disconnection: Schritt 8, Bild 3 von 3
    • Use the tip of a spudger to lift up the locking flap on the fan cable's ZIF connector.
    • Slide the fan cable out of the ZIF connector.
  9. Logic Board Disconnection: Schritt 9, Bild 1 von 2 Logic Board Disconnection: Schritt 9, Bild 2 von 2
    • Use a T3 Torx driver to remove the two 1.4 mm screws securing the antenna cable bracket.
    • Remove the antenna cable bracket.
  10. Logic Board Disconnection: Schritt 10, Bild 1 von 3 Logic Board Disconnection: Schritt 10, Bild 2 von 3 Logic Board Disconnection: Schritt 10, Bild 3 von 3
    • Insert the point of a spudger under one of the antenna cables close to the connector. Pry straight up to disconnect the cable.
    • Repeat for the other antenna cable.
  11. Logic Board Disconnection: Schritt 11, Bild 1 von 2 Logic Board Disconnection: Schritt 11, Bild 2 von 2
    • Use a T3 Torx driver to remove the two 1.5 mm screws securing the display cable connector bracket.
    • Remove the display cable connector bracket.
  12. Logic Board Disconnection: Schritt 12, Bild 1 von 2 Logic Board Disconnection: Schritt 12, Bild 2 von 2
    • Use the flat end of a spudger to pry up the display cable connector.
Abschluss
Adam O'Camb
196.326 Reputation
416 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 116
