Einleitung
This guide will show you how to replace the micro switches for the left and right mouse buttons of your Logitech G603 gaming mouse to resolve double-clicking issues.
This repair requires soldering so for those who are not experienced it may be a difficult repair. Please refer to the How to Solder and Desolder Connections for more information on soldering.
Was du brauchst
Flip the mouse onto its back.
Peel back the pads on the top and bottom of the mouse to reveal the four screws.
Remove the four screws with a small Philips screwdriver and set them aside.
Remove the battery plate and batteries.
Start at the same location as the previous step, and use your thumb to carefully pry the base from the shell of the mouse.
There will be two crevices that are attaching the base to the shell of the mouse.
Using a spudger, gently and carefully pry along the dotted red line marked in the first photo until the shell and the base are separated.
There will be two cables that need to be disconnected before completely separating the shell from the base.
To remove the ribbon cable, use your thumb and index finger to pinch the latch upwards.
Once the latch has been released, pull the cable out of its slot.
To remove the power cable, slowly and carefully wiggle the cable out of its socket either with your fingers, a spudger, or a flat head screwdriver.
Here, you will be able to see the underside location of the switches that need to be replaced.
Here, you can see the location of the next step which will be to unfasten the side button circuit board.
Locate the screw marked in the first photo. Remove it by using a Philips head screw driver and twisting in a counter-clockwise motion.
Use a screwdriver to remove the screw by twisting in a counter-clockwise motion.
Using a flat head screwdriver, push the latch upwards and into hole from which it protrudes until the cover loosens.
Using your index finger and thumb carefully displace the cover to reveal the switch.
The switch board will be secured by two screws. Using a Philips head screwdriver, remove the two screws using a counter-clockwise motion.
Using a spudger or a flat head screwdriver lift the circuit board from its slot.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Once there is enough room, pinch the board loose with your index finger and thumb
With the side board in hand, twist the board until there is enough room for the switch board to exit the gap located in the last photo.
Now that we have the first switch displaced, repeat steps 11-14 to displace the other.
Proceed to step 16 to remove the mouse switch from its hole
Now that the switches have been displaced, prepare your soldering equipment for the final steps.
In diesem Schritt verwendetes Werkzeug:Desoldering Pump$3.99
Remove solder from the pin joints to displace the switch by using solder pump.
Once the residual soldering flux has been clean, begin soldering in the new switch into the board. Repeat steps 19 and 20 for the other switch.
7 weitere Personen haben diese Anleitung absolviert.
3 Kommentare zur Anleitung
Excellent guide! Thank you for putting this together. I replaced my switches following my mouse double clicking on the left button about 5% of the time. The switches I ordered didn't have the right terminals (they were flat and short with holes in them). I had to truncate them a little to make them fit into the holes in the PCB. I also replaced both left and right buttons since the switches I ordered had a minimum order quantity of 5.
Perhaps indicate part number for the switches that are the correct type in the guide? I ordered the Omron model D2F-01F-D. They work great except for having the wrong terminals. You probably want to order the model D2F-01.
What an awesome guide. The pictures and detailed descriptions made it possible for me to follow even though I never do these things normally. I just thought I'd give it a try since it would save me so much money - and it did! :) Thanks man, you're a gem.
I got the replacement clicker called 2FC-F-7N (costs basically nothing) and it fits and works perfectly after installation.
I only know the basics of soldering, and haven't soldered anything for 15 years, but was able to change the component successfully, so it seems like it is somewhat forgiving even if you don't handle it perfectly.
Thanks for the Guide! managed to replace the switches on my mouse with kailh gm 8.0 after it had been getting on my nerves with false double clicks for a long long long time... (did this even without desoldering pump or wick, prying below the switches and heating up the solder spots one after the other dislodged the old switches bit by bit)
