Zum Hauptinhalt wechseln
Logitech G920 Driving Force Steering Wheel Motherboard Replacement
Was du brauchst
  1. Logitech G920 Driving Force Steering Wheel Motherboard Replacement, Steering Wheel Motherboard: Schritt 1, Bild 1 von 1
    • Use the Phillips #0 screwdriver to remove the five 9.5 mm external screws.
    • Only three of the five screws are visible from each side of the wheel due to the center unit.
  2. Logitech G920 Driving Force Steering Wheel Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Using the Phillips #0 screwdriver, remove the 5 mm screws holding the bumpers in place.
  3. Logitech G920 Driving Force Steering Wheel Motherboard Replacement: Schritt 3, Bild 1 von 2 Logitech G920 Driving Force Steering Wheel Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Using the TR25 Torx Security Screwdriver, remove the six 23.8 mm screws holding the face plate together.
    • Remove the face plate from the steering wheel.
  4. Logitech G920 Driving Force Steering Wheel Motherboard Replacement: Schritt 4, Bild 1 von 2 Logitech G920 Driving Force Steering Wheel Motherboard Replacement: Schritt 4, Bild 2 von 2
    • Remove the wheel from the main steering wheel console.
    • Ensure this is done carefully as to not damage the connection wire.
  5. Logitech G920 Driving Force Steering Wheel Motherboard Replacement: Schritt 5, Bild 1 von 2 Logitech G920 Driving Force Steering Wheel Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Remove the eight 7.5 mm screws holding the steering wheel motherboard in place using a Phillips #0 screwdriver.
    • Remove the steering wheel motherboard.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Tristyn Dolan
300 Reputation
2 Anleitungen geschrieben
Ein Kommentar
what is on the wire that connect to the motherborade
saleh - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 20
Letzte 30 Tage: 84
Insgesamt: 1,269
