Zum Hauptinhalt wechseln
Logitech G920 Driving Force XYAB Buttons Replacement
Was du brauchst
  1. Logitech G920 Driving Force XYAB Buttons Replacement, Steering Wheel Motherboard: Schritt 1, Bild 1 von 1
    • Use the Phillips #0 screwdriver to remove the five 9.5 mm external screws.
    • Only three of the five screws are visible from each side of the wheel due to the center unit.
  2. Logitech G920 Driving Force XYAB Buttons Replacement: Schritt 2, Bild 1 von 1
    • Using the Phillips #0 screwdriver, remove the 5 mm screws holding the bumpers in place.
  3. Logitech G920 Driving Force XYAB Buttons Replacement: Schritt 3, Bild 1 von 2 Logitech G920 Driving Force XYAB Buttons Replacement: Schritt 3, Bild 2 von 2
    • Using the TR25 Torx Security Screwdriver, remove the six 23.8 mm screws holding the face plate together.
    • Remove the face plate from the steering wheel.
  4. Logitech G920 Driving Force XYAB Buttons Replacement: Schritt 4, Bild 1 von 2 Logitech G920 Driving Force XYAB Buttons Replacement: Schritt 4, Bild 2 von 2
    • Remove the wheel from the main steering wheel console.
    • Ensure this is done carefully as to not damage the connection wire.
  5. Logitech G920 Driving Force XYAB Buttons Replacement: Schritt 5, Bild 1 von 2 Logitech G920 Driving Force XYAB Buttons Replacement: Schritt 5, Bild 2 von 2
    • Remove the eight 7.5 mm screws holding the steering wheel motherboard in place using a Phillips #0 screwdriver.
    • Remove the steering wheel motherboard.
  6. Logitech G920 Driving Force XYAB Buttons Replacement, XYAB Buttons: Schritt 6, Bild 1 von 1
    • Remove the XYAB buttons from the back of the steering wheel.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Tristyn Dolan
300 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 34
Insgesamt: 507
