Zum Hauptinhalt wechseln
Logitech Harmony Smart Control Battery Contact Replacement
Was du brauchst
  1. Logitech Harmony Smart Control Battery Contact  Replacement, Battery Contact: Schritt 1, Bild 1 von 2 Logitech Harmony Smart Control Battery Contact  Replacement, Battery Contact: Schritt 1, Bild 2 von 2
    • Use both thumbs to slide the grooved cover off of the remote
    • Once the cover is off, remove the battery.
  2. Logitech Harmony Smart Control Battery Contact  Replacement: Schritt 2, Bild 1 von 2 Logitech Harmony Smart Control Battery Contact  Replacement: Schritt 2, Bild 2 von 2
    • Locate both of the 4mm Phillips screws on the remote. Using the PH00 bit, remove the screws.
  3. Logitech Harmony Smart Control Battery Contact  Replacement: Schritt 3, Bild 1 von 3 Logitech Harmony Smart Control Battery Contact  Replacement: Schritt 3, Bild 2 von 3 Logitech Harmony Smart Control Battery Contact  Replacement: Schritt 3, Bild 3 von 3
    • Use a flat screwdriver or a prying tool to split the remote and separate the two pieces. Start from the bottom.
  4. Logitech Harmony Smart Control Battery Contact  Replacement: Schritt 4, Bild 1 von 2 Logitech Harmony Smart Control Battery Contact  Replacement: Schritt 4, Bild 2 von 2
    • Using the metal piece from the housing, pry the circuit board upwards. Do not disconnect it from the board.
    • Slide the circuit board out from the housing .
  5. Logitech Harmony Smart Control Battery Contact  Replacement: Schritt 5, Bild 1 von 1
    • Locate the battery contacts on the circuit board.
    • Using a soldering iron, remove the old solder and the battery contacts. Install new battery contacts and solder them.
Abschluss
Josh Hendricks
464 Reputation
4 Anleitungen geschrieben
IUPUI, Team 3-2, Harley Fall 2015 Mitglied von IUPUI, Team 3-2, Harley Fall 2015
IUPUI-HARLEY-F15S3G2
4 Mitglieder
5 Anleitungen geschrieben
Ein Kommentar
do you know where can i buy the springs?
IOANNIS KARAKOGLOU - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 20
Insgesamt: 4,930
