Einleitung
This guide requires soldering, for soldering guide click below.
Was du brauchst
Use both thumbs to slide the grooved cover off of the remote
Once the cover is off, remove the battery.
Locate both of the 4mm Phillips screws on the remote. Using the PH00 bit, remove the screws.
Use a flat screwdriver or a prying tool to split the remote and separate the two pieces. Start from the bottom.
Using the metal piece from the housing, pry the circuit board upwards. Do not disconnect it from the board.
Slide the circuit board out from the housing .
Locate the battery contacts on the circuit board.
Using a soldering iron, remove the old solder and the battery contacts. Install new battery contacts and solder them.
