Zum Hauptinhalt wechseln
Logitech Harmony Smart Control Charging Port Replacement
Was du brauchst
  1. Logitech Harmony Smart Control Charging Port Replacement, Charging Port: Schritt 1, Bild 1 von 2 Logitech Harmony Smart Control Charging Port Replacement, Charging Port: Schritt 1, Bild 2 von 2
    • Use the plastic opening tool to lift up the rubber pad.
    • With your fingers, pull back the rubber pad. This will expose the screw holes on the bottom of the device.
    • Repeat the step above for the second rubber pad on the bottom of the hub.
  2. Logitech Harmony Smart Control Charging Port Replacement: Schritt 2, Bild 1 von 2 Logitech Harmony Smart Control Charging Port Replacement: Schritt 2, Bild 2 von 2
    • Using the PH00 bit, remove the four 6mm Phillips screws
  3. Logitech Harmony Smart Control Charging Port Replacement: Schritt 3, Bild 1 von 2 Logitech Harmony Smart Control Charging Port Replacement: Schritt 3, Bild 2 von 2
    • Use the plastic opening tool to pry open and separate the pieces of plastic from each other.
  4. Logitech Harmony Smart Control Charging Port Replacement: Schritt 4, Bild 1 von 2 Logitech Harmony Smart Control Charging Port Replacement: Schritt 4, Bild 2 von 2
    • Using the PH00 bit, remove the three 4mm Phillips screws.
  5. Logitech Harmony Smart Control Charging Port Replacement: Schritt 5, Bild 1 von 3 Logitech Harmony Smart Control Charging Port Replacement: Schritt 5, Bild 2 von 3 Logitech Harmony Smart Control Charging Port Replacement: Schritt 5, Bild 3 von 3
    • Starting at the yellow corner, use a plastic opening tool to pry the circuit board from the housing.
  6. Logitech Harmony Smart Control Charging Port Replacement: Schritt 6, Bild 1 von 3 Logitech Harmony Smart Control Charging Port Replacement: Schritt 6, Bild 2 von 3 Logitech Harmony Smart Control Charging Port Replacement: Schritt 6, Bild 3 von 3
    • Locate the defective charging port.
    • Turn the circuit board over to expose the charging solder.
    • Using a soldering iron, remove the solder and the charging port. Install a new charging port and solder.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Josh Hendricks
464 Reputation
4 Anleitungen geschrieben
IUPUI, Team 3-2, Harley Fall 2015 Mitglied von IUPUI, Team 3-2, Harley Fall 2015
IUPUI-HARLEY-F15S3G2
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 10
Insgesamt: 711
