Zum Hauptinhalt wechseln
Logitech Harmony Smart Control Reset Button Replacement
Was du brauchst
  1. Logitech Harmony Smart Control Reset Button Replacement, Reset Button: Schritt 1, Bild 1 von 2 Logitech Harmony Smart Control Reset Button Replacement, Reset Button: Schritt 1, Bild 2 von 2
    • Using a plastic opening tool, lift up the rubber pad.
    • From the bottom of the device, with your fingers, pull back the rubber pad. This will expose the screw holes.
    • On the bottom of the hub, repeat the step above for the second rubber pad.
  2. Logitech Harmony Smart Control Reset Button Replacement: Schritt 2, Bild 1 von 2 Logitech Harmony Smart Control Reset Button Replacement: Schritt 2, Bild 2 von 2
    • With the PH00 bit, remove the four 6mm Phillips screws.
  3. Logitech Harmony Smart Control Reset Button Replacement: Schritt 3, Bild 1 von 2 Logitech Harmony Smart Control Reset Button Replacement: Schritt 3, Bild 2 von 2
    • With the plastic opening tool, separate the pieces of plastic from each other
  4. Logitech Harmony Smart Control Reset Button Replacement: Schritt 4, Bild 1 von 2 Logitech Harmony Smart Control Reset Button Replacement: Schritt 4, Bild 2 von 2
    • With the PH00 bit, remove the three 4mm Phillips screws.
  5. Logitech Harmony Smart Control Reset Button Replacement: Schritt 5, Bild 1 von 3 Logitech Harmony Smart Control Reset Button Replacement: Schritt 5, Bild 2 von 3 Logitech Harmony Smart Control Reset Button Replacement: Schritt 5, Bild 3 von 3
    • From the yellow corner, pry the circuit board from the housing..
  6. Logitech Harmony Smart Control Reset Button Replacement: Schritt 6, Bild 1 von 3 Logitech Harmony Smart Control Reset Button Replacement: Schritt 6, Bild 2 von 3 Logitech Harmony Smart Control Reset Button Replacement: Schritt 6, Bild 3 von 3
    • Locate the defective reset button.
    • Turn the board around to expose the reset solder.
    • Using soldering iron, remove solder and reset button. Replace reset button and solder.
Abschluss
IUPUI, Team 3-2, Harley Fall 2015 Mitglied von IUPUI, Team 3-2, Harley Fall 2015
IUPUI-HARLEY-F15S3G2
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 5
Insgesamt: 1,056
