Zum Hauptinhalt wechseln
Logitech UE Boombox Speaker Replacement
Was du brauchst
  1. Logitech UE Boombox Speaker Replacement, Speaker Grille: Schritt 1, Bild 1 von 2 Logitech UE Boombox Speaker Replacement, Speaker Grille: Schritt 1, Bild 2 von 2
    • Use a metal spudger to pry open the power button cover.
    • Once the power button cover is slightly opened, use your fingers to remove the power button cover.
  2. Logitech UE Boombox Speaker Replacement: Schritt 2, Bild 1 von 3 Logitech UE Boombox Speaker Replacement: Schritt 2, Bild 2 von 3 Logitech UE Boombox Speaker Replacement: Schritt 2, Bild 3 von 3
    • Press firmly on the end of the latch and pull the two-wire connector away from the base to separate.
  3. Logitech UE Boombox Speaker Replacement: Schritt 3, Bild 1 von 3 Logitech UE Boombox Speaker Replacement: Schritt 3, Bild 2 von 3 Logitech UE Boombox Speaker Replacement: Schritt 3, Bild 3 von 3
    • Firmly press on the end of the latch and pull the four-wire connector away from the base to separate.
  4. Logitech UE Boombox Speaker Replacement: Schritt 4, Bild 1 von 3 Logitech UE Boombox Speaker Replacement: Schritt 4, Bild 2 von 3 Logitech UE Boombox Speaker Replacement: Schritt 4, Bild 3 von 3
    • Lightly, pry up on each side of the black band connector lock using your fingertips.
    • Once unlocked, pull straight up on the connector to remove.
  5. Logitech UE Boombox Speaker Replacement: Schritt 5, Bild 1 von 2 Logitech UE Boombox Speaker Replacement: Schritt 5, Bild 2 von 2
    • Remove the five black 14mm Phillips #2 screws from the black plastic side panel.
    • Remove the one silver 16mm Phillips #2 screws from the black plastic side panel.
    • Remove the black plastic screw panel from the boombox.
  6. Logitech UE Boombox Speaker Replacement: Schritt 6, Bild 1 von 2 Logitech UE Boombox Speaker Replacement: Schritt 6, Bild 2 von 2
    • On the opposite side of the device, pry open the volume rocker with a metal spudger.
    • Remove the panel with your fingers once the volume rocker is slightly opened.
  7. Logitech UE Boombox Speaker Replacement: Schritt 7, Bild 1 von 3 Logitech UE Boombox Speaker Replacement: Schritt 7, Bild 2 von 3 Logitech UE Boombox Speaker Replacement: Schritt 7, Bild 3 von 3
    • Remove the one silver16 mm Phillips #2 screw from the black plastic side panel.
    • Once all screws are removed, take the screw panel out of the device to gain access to the back of the panel.
  8. Logitech UE Boombox Speaker Replacement: Schritt 8, Bild 1 von 2 Logitech UE Boombox Speaker Replacement: Schritt 8, Bild 2 von 2
    • Firmly press on the end of the latch and pull the two-wire connector away from the base.
  9. Logitech UE Boombox Speaker Replacement: Schritt 9, Bild 1 von 2 Logitech UE Boombox Speaker Replacement: Schritt 9, Bild 2 von 2
    • Pull up on the aluminum boombox handle to remove.
  10. Logitech UE Boombox Speaker Replacement: Schritt 10, Bild 1 von 2 Logitech UE Boombox Speaker Replacement: Schritt 10, Bild 2 von 2
    • Use a metal spudger to pry the rubber base apart from the aluminum grille.
  11. Logitech UE Boombox Speaker Replacement: Schritt 11, Bild 1 von 2 Logitech UE Boombox Speaker Replacement: Schritt 11, Bild 2 von 2
    • Pull the rubber base away from the boombox.
  12. Logitech UE Boombox Speaker Replacement: Schritt 12, Bild 1 von 1
    • Remove the four black 7.5mm Phillips #2 screws on each side of the device.
    • There should be a total of eight screws removed in this step.
  13. Logitech UE Boombox Speaker Replacement: Schritt 13, Bild 1 von 3 Logitech UE Boombox Speaker Replacement: Schritt 13, Bild 2 von 3 Logitech UE Boombox Speaker Replacement: Schritt 13, Bild 3 von 3
    • Pull vertically on the speaker grille to remove it from the boombox.
  14. Logitech UE Boombox Speaker Replacement, Speaker: Schritt 14, Bild 1 von 3 Logitech UE Boombox Speaker Replacement, Speaker: Schritt 14, Bild 2 von 3 Logitech UE Boombox Speaker Replacement, Speaker: Schritt 14, Bild 3 von 3
    • Remove the fifteen 13.0 mm screws with a #0 Phillips from the side of the device containing two speakers.
    • Separate the two halves by gently pulling them apart.
    • The screws at this step are embedded deep within the device so make sure your screw driver is long.
  15. Logitech UE Boombox Speaker Replacement: Schritt 15, Bild 1 von 1
    • Locate the speaker adjacent to the motherboard.
  16. Logitech UE Boombox Speaker Replacement: Schritt 16, Bild 1 von 3 Logitech UE Boombox Speaker Replacement: Schritt 16, Bild 2 von 3 Logitech UE Boombox Speaker Replacement: Schritt 16, Bild 3 von 3
  17. Logitech UE Boombox Speaker Replacement: Schritt 17, Bild 1 von 1
    • Remove the four 7.0 mm screws with a Phillips #2.
  18. Logitech UE Boombox Speaker Replacement: Schritt 18, Bild 1 von 2 Logitech UE Boombox Speaker Replacement: Schritt 18, Bild 2 von 2
    • Lift the speaker out of the device using your fingers.
  19. Logitech UE Boombox Speaker Replacement: Schritt 19, Bild 1 von 3 Logitech UE Boombox Speaker Replacement: Schritt 19, Bild 2 von 3 Logitech UE Boombox Speaker Replacement: Schritt 19, Bild 3 von 3
    • Pull up on the lock to detach the band connector from the motherboard.
  20. Logitech UE Boombox Speaker Replacement: Schritt 20, Bild 1 von 1
    • Remove five 7.0 mm screws on the motherboard with a Phillips #2.
  21. Logitech UE Boombox Speaker Replacement: Schritt 21, Bild 1 von 3 Logitech UE Boombox Speaker Replacement: Schritt 21, Bild 2 von 3 Logitech UE Boombox Speaker Replacement: Schritt 21, Bild 3 von 3
    • Lift the motherboard with your fingers.
    • Flip over to reveal the underside.
    • Motherboard will still be attached to the device.
  22. Logitech UE Boombox Speaker Replacement: Schritt 22, Bild 1 von 3 Logitech UE Boombox Speaker Replacement: Schritt 22, Bild 2 von 3 Logitech UE Boombox Speaker Replacement: Schritt 22, Bild 3 von 3
    • Pull up on the lock of the band connector to detach it from the motherboard.
  23. Logitech UE Boombox Speaker Replacement: Schritt 23, Bild 1 von 3 Logitech UE Boombox Speaker Replacement: Schritt 23, Bild 2 von 3 Logitech UE Boombox Speaker Replacement: Schritt 23, Bild 3 von 3
    • Desolder all four wires connecting the speaker.
    • One red and one black wire are located on each side of speaker.
  24. Logitech UE Boombox Speaker Replacement: Schritt 24, Bild 1 von 1
    • Remove four 7.0 mm screws with a Phillips #2.
  25. Logitech UE Boombox Speaker Replacement: Schritt 25, Bild 1 von 2 Logitech UE Boombox Speaker Replacement: Schritt 25, Bild 2 von 2
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Breean Mokede
282 Reputation
2 Anleitungen geschrieben
CSU Fullerton, Team 1-1, Bruce Fall 2016 Mitglied von CSU Fullerton, Team 1-1, Bruce Fall 2016
CSUF-BRUCE-F16S1G1
4 Mitglieder
5 Anleitungen geschrieben
Ein Kommentar
Could you recommend anywhere to find the correct replacement tweeters & drivers?
Ted Glasgow - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 40
Insgesamt: 2,372
