Einleitung
A soldering kit is necessary to completely isolate the motherboard as we will be needing to desolder the USB and camera joints.
Was du brauchst
Remove the four 6mm Phillips #0 screws connecting the motherboard and front cover.
Grasp the white connector attaching the button chip wire to the motherboard.
Wiggle the connector back and forth to remove it from the connection box
Grasp the white wire connector between the tabs and the socket.
Wiggle the connector back and forth to remove the front cover from the motherboard.
Use tweezers to grasp the white wire connector on the back of the motherboard.
Wiggle the connector back and forth to remove it from the socket.
Desolder the joint on the front of the motherboard to completely detach the USB cable.
Remove the camera from the motherboard by desoldering the two connections as shown.
Eine weitere Person hat diese Anleitung absolviert.
