Einleitung
This guide will tell MSI GT72 2QE Dominator Pro users how to replace a defective battery. It is a medium-level process that takes 15-20 minutes to complete.
For your safety, discharge your battery below 25% before disassembling your device. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Was du brauchst
Use a Phillips screwdriver to remove the seven 6mm screws from the bottom of the laptop.
Lift and remove the bottom case off of the laptop.
Use a Phillips screwdriver to remove one 4 mm screw and one 10 mm screw from each fan.
Unplug both fans by gently disconnecting the fan connector from its motherboard socket. If you have trouble, gently wiggle the connector to loosen it.
Unplug both red and black speaker cables. Pull straight out so the connectors aren't damaged.
Disconnect both these cables carefully by lifting the pressure tabs then gently pulling.
Use a card or other flat object to lift and remove the battery from the housing.
Replace the battery with a 11.1V, 7500mAh Li-ion battery, MSI part number: BTY-L77 or equivalent.
Run MSI Battery Calibration to make sure the firmware can see the new batteries cycle high low voltages.
29 weitere Personen haben diese Anleitung absolviert.
17 Kommentare
Hi,
on the steep 7, you forgot a screw : just above the orange part of the heat sink.
great guide otherwise :D
And another one near the bass speaker
Did it but I was left with one screw. Have no idea where it goes. But hey battery works and not complaining.
Anyone know where to find a GT72 Dominator battery?
I bought mine here: http://www.fr-batterie.com/
Thanks for this tutorial!
I used it to replace my GT72 2QD Dominator battery. It’s almost the same (yet, not a piece of cake).
Cameron -
