Einleitung
更换您的硬盘时,将旧硬盘上的梅花螺丝转移到新的上面。
Was du brauchst
Einführungsvideo
如需重新组装您的设备,请按照相反的顺序执行这些指示。
348 weitere Nutzer:innen haben diese Anleitung absolviert.
100%
Hier starten ›
21 Kommentare
can i install an ssd instead of a normal hd?
Yes, absolutely. I switched mine out with a Kingston 120GB SSD.
By the looks of it. The Crucial MX100 is explicitly said to be compatible and has SATA III:
Albert -
