Zum Hauptinhalt wechseln
MacBook Air 11" Mid 2013 Display Assembly Replacement
Was du brauchst
  1. MacBook Air 11" Mid 2013 Display Assembly Replacement, Lower Case: Schritt 1, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    Kaufen
    • Shut down and close your computer. Lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
  2. MacBook Air 11" Mid 2013 Display Assembly Replacement: Schritt 2, Bild 1 von 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 11" Mid 2013 Display Assembly Replacement, Battery Connector: Schritt 3, Bild 1 von 2 MacBook Air 11" Mid 2013 Display Assembly Replacement, Battery Connector: Schritt 3, Bild 2 von 2
    • In this step you will disconnect the battery to help avoid shorting out any components during service.
    • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
    • Bend the battery cable slightly away from the logic board so the connector will not accidentally bend back and make contact with its socket.
  4. MacBook Air 11" Mid 2013 Display Assembly Replacement, I/O Board Cable: Schritt 4, Bild 1 von 2 MacBook Air 11" Mid 2013 Display Assembly Replacement, I/O Board Cable: Schritt 4, Bild 2 von 2
    • Use the flat end of a spudger to pry the left and right I/O board cable connectors up off their respective sockets on the I/O board.
  5. MacBook Air 11" Mid 2013 Display Assembly Replacement: Schritt 5, Bild 1 von 1
    • Lift and remove the I/O board cable.
  6. MacBook Air 11" Mid 2013 Display Assembly Replacement, Fan: Schritt 6, Bild 1 von 2 MacBook Air 11" Mid 2013 Display Assembly Replacement, Fan: Schritt 6, Bild 2 von 2
    • Use the tip of a spudger to carefully push on each side of the iSight camera cable connector to loosen it out of its socket on the logic board.
    • We recommend you gently "walk" the connector out of its socket.
  7. MacBook Air 11" Mid 2013 Display Assembly Replacement: Schritt 7, Bild 1 von 2 MacBook Air 11" Mid 2013 Display Assembly Replacement: Schritt 7, Bild 2 von 2
    • Peel the iSight camera cable up off the adhesive securing it to the fan.
  8. MacBook Air 11" Mid 2013 Display Assembly Replacement: Schritt 8, Bild 1 von 2 MacBook Air 11" Mid 2013 Display Assembly Replacement: Schritt 8, Bild 2 von 2
    • Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
  9. MacBook Air 11" Mid 2013 Display Assembly Replacement: Schritt 9, Bild 1 von 1
    • Remove the following three screws securing the fan to the upper case:
    • Two 5.5 mm T5 Torx screws
    • One 4.6 mm T5 Torx screw
    • In some models this is a 3.6 mm T5 Torx screw.
  10. MacBook Air 11" Mid 2013 Display Assembly Replacement: Schritt 10, Bild 1 von 3 MacBook Air 11" Mid 2013 Display Assembly Replacement: Schritt 10, Bild 2 von 3 MacBook Air 11" Mid 2013 Display Assembly Replacement: Schritt 10, Bild 3 von 3
    • Lift, but do not remove the fan out of its recess in the upper case.
    • Carefully pull the fan ribbon cable out of its socket as you remove the fan from the Air.
  11. MacBook Air 11" Mid 2013 Display Assembly Replacement, Logic Board Assembly: Schritt 11, Bild 1 von 3 MacBook Air 11" Mid 2013 Display Assembly Replacement, Logic Board Assembly: Schritt 11, Bild 2 von 3 MacBook Air 11" Mid 2013 Display Assembly Replacement, Logic Board Assembly: Schritt 11, Bild 3 von 3
    • Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth card, and move them out of the way.
  12. MacBook Air 11" Mid 2013 Display Assembly Replacement: Schritt 12, Bild 1 von 1
    • Remove the following five screws securing the battery to the upper case:
    • Two 5.2 mm T5 Torx screws
    • One 6 mm T5 Torx screw
    • Two 2.6 mm T5 Torx screws
  13. MacBook Air 11" Mid 2013 Display Assembly Replacement: Schritt 13, Bild 1 von 1
    • When handling the battery, avoid squeezing or touching the six exposed lithium polymer cells.
    • Lift the battery from its edge nearest the logic board and remove it from the upper case.
  14. MacBook Air 11" Mid 2013 Display Assembly Replacement: Schritt 14, Bild 1 von 2 MacBook Air 11" Mid 2013 Display Assembly Replacement: Schritt 14, Bild 2 von 2
    • Disconnect the I/O board by pulling the power cable away from its socket on the logic board.
    • Pull the cable parallel to the face of the logic board toward the front edge of the Air.
  15. MacBook Air 11" Mid 2013 Display Assembly Replacement: Schritt 15, Bild 1 von 3 MacBook Air 11" Mid 2013 Display Assembly Replacement: Schritt 15, Bild 2 von 3 MacBook Air 11" Mid 2013 Display Assembly Replacement: Schritt 15, Bild 3 von 3
    • Use the tip of a spudger to de-route the antenna cables from their notches in the logic board.
  16. MacBook Air 11" Mid 2013 Display Assembly Replacement: Schritt 16, Bild 1 von 3 MacBook Air 11" Mid 2013 Display Assembly Replacement: Schritt 16, Bild 2 von 3 MacBook Air 11" Mid 2013 Display Assembly Replacement: Schritt 16, Bild 3 von 3
    • Gently push the tip of a spudger under the black plastic flap stuck to the display data cable lock to make the lock pop upward and away from the socket.
    • While holding the lock away from the socket, gently pull the display data cable out of its socket.
    • Do not pull upward on the display data cable as you disconnect it, as its socket may break off the logic board.
  17. MacBook Air 11" Mid 2013 Display Assembly Replacement: Schritt 17, Bild 1 von 3 MacBook Air 11" Mid 2013 Display Assembly Replacement: Schritt 17, Bild 2 von 3 MacBook Air 11" Mid 2013 Display Assembly Replacement: Schritt 17, Bild 3 von 3
    • Use the tip of a spudger to pry under the speaker cable connector, lifting it straight up from its socket.
    • De-route the cable from its notch in the logic board.
  18. MacBook Air 11" Mid 2013 Display Assembly Replacement: Schritt 18, Bild 1 von 3 MacBook Air 11" Mid 2013 Display Assembly Replacement: Schritt 18, Bild 2 von 3 MacBook Air 11" Mid 2013 Display Assembly Replacement: Schritt 18, Bild 3 von 3
    • Use the tip of a spudger or your fingernail to flip up the retaining flap on the trackpad ribbon cable ZIF socket.
    • Pull the trackpad ribbon cable straight out of its socket toward the front edge of the Air.
  19. MacBook Air 11" Mid 2013 Display Assembly Replacement: Schritt 19, Bild 1 von 3 MacBook Air 11" Mid 2013 Display Assembly Replacement: Schritt 19, Bild 2 von 3 MacBook Air 11" Mid 2013 Display Assembly Replacement: Schritt 19, Bild 3 von 3
    • Use the tip of a spudger to flip up the retaining flap on the keyboard backlight ribbon cable ZIF socket.
    • Pull the keyboard backlight ribbon cable out of its socket.
  20. MacBook Air 11" Mid 2013 Display Assembly Replacement: Schritt 20, Bild 1 von 1
    • Remove the single 2.9 mm T5 Torx screw securing the AirPort/Bluetooth card to the logic board.
  21. MacBook Air 11" Mid 2013 Display Assembly Replacement: Schritt 21, Bild 1 von 3 MacBook Air 11" Mid 2013 Display Assembly Replacement: Schritt 21, Bild 2 von 3 MacBook Air 11" Mid 2013 Display Assembly Replacement: Schritt 21, Bild 3 von 3
    • Slightly lift the free end of the AirPort/Bluetooth board and pull it out of its socket on the logic board.
    • To avoid damaging its socket on the logic board, do not excessively lift the free end of the AirPort/Bluetooth card.
  22. MacBook Air 11" Mid 2013 Display Assembly Replacement: Schritt 22, Bild 1 von 1
    • Remove the three 3.6 mm T5 Torx screws securing the logic board to the upper case.
    • In some models these are 3.1 mm T5 Torx screws.
  23. MacBook Air 11" Mid 2013 Display Assembly Replacement: Schritt 23, Bild 1 von 3 MacBook Air 11" Mid 2013 Display Assembly Replacement: Schritt 23, Bild 2 von 3 MacBook Air 11" Mid 2013 Display Assembly Replacement: Schritt 23, Bild 3 von 3
    • Gently lift the logic board assembly from the heat sink end and pull it away from the port side of the case to remove it from the Air.
    • When replacing the logic board, insert the board's rubber edge under the port-side rubber gasket, then lower the board into place.
  24. MacBook Air 11" Mid 2013 Display Assembly Replacement, I/O Board: Schritt 24, Bild 1 von 3 MacBook Air 11" Mid 2013 Display Assembly Replacement, I/O Board: Schritt 24, Bild 2 von 3 MacBook Air 11" Mid 2013 Display Assembly Replacement, I/O Board: Schritt 24, Bild 3 von 3
    • Remove the small rubber gasket from the corner of the upper case nearest the the I/O board.
    • Remove the gasket from the corner nearest display cable connector.
  25. MacBook Air 11" Mid 2013 Display Assembly Replacement: Schritt 25, Bild 1 von 2 MacBook Air 11" Mid 2013 Display Assembly Replacement: Schritt 25, Bild 2 von 2
    • If necessary, use tweezers to remove any tape covering the microphone cable ZIF connector.
  26. MacBook Air 11" Mid 2013 Display Assembly Replacement: Schritt 26, Bild 1 von 3 MacBook Air 11" Mid 2013 Display Assembly Replacement: Schritt 26, Bild 2 von 3 MacBook Air 11" Mid 2013 Display Assembly Replacement: Schritt 26, Bild 3 von 3
    • Use the tip of a spudger to carefully flip up the retaining flap on the microphone cable ZIF socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • With a pair of tweezers, pull the microphone ribbon cable straight out of its socket.
  27. MacBook Air 11" Mid 2013 Display Assembly Replacement: Schritt 27, Bild 1 von 3 MacBook Air 11" Mid 2013 Display Assembly Replacement: Schritt 27, Bild 2 von 3 MacBook Air 11" Mid 2013 Display Assembly Replacement: Schritt 27, Bild 3 von 3
    • Use the tip of a spudger to pry under the speaker cable near the connector, lifting it straight up from its socket.
  28. MacBook Air 11" Mid 2013 Display Assembly Replacement: Schritt 28, Bild 1 von 1
    • Remove the single 3.6 mm T5 Torx screw securing the I/O board to the upper case.
  29. MacBook Air 11" Mid 2013 Display Assembly Replacement: Schritt 29, Bild 1 von 3 MacBook Air 11" Mid 2013 Display Assembly Replacement: Schritt 29, Bild 2 von 3 MacBook Air 11" Mid 2013 Display Assembly Replacement: Schritt 29, Bild 3 von 3
    • Carefully lift the I/O board by its power cable and pull it away from the edge of the case.
  30. MacBook Air 11" Mid 2013 Display Assembly Replacement, Display Assembly: Schritt 30, Bild 1 von 3 MacBook Air 11" Mid 2013 Display Assembly Replacement, Display Assembly: Schritt 30, Bild 2 von 3 MacBook Air 11" Mid 2013 Display Assembly Replacement, Display Assembly: Schritt 30, Bild 3 von 3
    • Peel up the six cable loops securing the antenna cables to the upper case.
    • In some models there are seven cable loops.
    • Gently pull the cable loops slightly out of the channel cut into the upper case one at a time.
    • Use your spudger to open up the plastic loops as you de-route the antenna cables through them.
    • Repeat this for each retaining loop until the antenna cables are free from the upper case.
  31. MacBook Air 11" Mid 2013 Display Assembly Replacement: Schritt 31, Bild 1 von 2 MacBook Air 11" Mid 2013 Display Assembly Replacement: Schritt 31, Bild 2 von 2
    • Remove the inner 4.9 mm T8 Torx screw securing each display hinge to the upper case (two screws total).
  32. MacBook Air 11" Mid 2013 Display Assembly Replacement: Schritt 32, Bild 1 von 1
    • Open the display until it is perpendicular to the upper case and place it on a table as shown.
    • While holding the Air steady, remove the remaining 4.9 mm T8 Torx screw from the lower display bracket.
  33. MacBook Air 11" Mid 2013 Display Assembly Replacement: Schritt 33, Bild 1 von 1
    • Before removing the last display screw, be sure to hold the display and upper case steady with your other hand. Failure to do so may allow the components to fall onto the table, causing potentially expensive damage.
    • Remove the last 4.9 mm T8 Torx screw securing the display to the upper case.
  34. MacBook Air 11" Mid 2013 Display Assembly Replacement: Schritt 34, Bild 1 von 2 MacBook Air 11" Mid 2013 Display Assembly Replacement: Schritt 34, Bild 2 von 2
    • Push the upper case slightly toward the display assembly, then rotate it away from the front of the display assembly.
    • Once the two display hinges have cleared the upper case, remove the display.
Abschluss
29 weitere Nutzer:innen haben diese Anleitung absolviert.
Sam Goldheart
465.762 Reputation
538 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
135 Mitglieder
16.817 Anleitungen geschrieben
3 Kommentare
Great tutorial. Easy to follow. Don't be afraid to do it.
Corey Campbell - Antwort
I wish the tutorial showed the procedure for tearing down the LCD and backlight panel... So not fun.
Sam Anticks - Antwort
is this Display of macbook air mid 2013 can fit into macbook air mid 2012?
juantajoe - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 21
Letzte 30 Tage: 98
Insgesamt: 23,253
