Einleitung
The MacBook Air hinges house the Webcam, Wifi/Bluetooth Antennae and the Display Connectors within them. This guide will show you how to remove the bezel and replace the hinges and also replace these connectors.
Was du brauchst
Slide the plastic chin to the right and off the display.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Remove the gasket that runs along the perimeter of the display. You can use a spudger to pry up the bezel and tweezers to pull it out.
Begin Prying from the right corner as pictured.
Remove the two PH000 screws holding in the LCD board in
To replace the display connection you can open the retaining latch and disconnect the cable.
Remove the three T8 Torx screws
Remove the PH000 screw
Flip the board over and disconnect it.
The Wifi / Bluetooth / Webcam cable can now be removed and replaced.
To reassemble your device, follow these instructions in reverse order. I recommend cleaning it with alcohol and using VHB tape for glueing the bezel back on.
2 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
Buen paso a paso, pero es de tener en cuenta 2 consideraciones. 1. al momento de la apertura, ¿donde se consigue una cama calefactora tran grande?. 2. al momento del sellado, ¿se debe usar un adesivo especial?
