Einleitung
Your Air is thirsty! Keep those electrons flowing and fix your broken DC-In board.
Werkzeuge
Ersatzteile
Remove ten Phillips screws securing the lower case to the MacBook Air:
Six 2.8 mm screws
Two 3.8 mm screws
Two 5.4 mm screws
Slightly lift the lower case near the vents and push it toward the rear of the computer to free the mounting tabs.
Disconnect the battery connector by pulling it straight out of its socket.
Remove the following nine screws securing the battery to the Air:
Four 2.9 mm Phillips.
Four 3.8 mm Phillips.
One 7.2 mm Phillips.
Remove the single Phillips screw securing the display data cable ground loop to the upper case.
Lift the display data cable slightly for enough clearance to remove the two Phillips screws securing the DC-In board to the upper case.
Lift the DC-In board slightly and pull its connector straight away from the socket on the logic board.
2 weitere Nutzer haben diese Anleitung absolviert.
