Zum Hauptinhalt wechseln
Einleitung
The ins and outs of replacing your trackpad control cable.
  1. Unplug your MacBook Air and power it off before you proceed.
    • Unplug your MacBook Air and power it off before you proceed.
    • Remove ten Phillips screws securing the lower case to the MacBook Air:
    • Six 2.8 mm screws
    • Two 3.8 mm screws
    • Two 5.4 mm screws
  2. Slightly lift the lower case near the vents and push it toward the rear of the computer to free the mounting tabs. Slightly lift the lower case near the vents and push it toward the rear of the computer to free the mounting tabs.
    • Slightly lift the lower case near the vents and push it toward the rear of the computer to free the mounting tabs.
  3. Disconnect the battery connector by pulling it straight out of its socket.
    • Disconnect the battery connector by pulling it straight out of its socket.
  4. Remove the following nine screws securing the battery to the Air:
    • Remove the following nine screws securing the battery to the Air:
    • Four 2.9 mm Phillips.
    • Four 3.8 mm Phillips.
    • One 7.2 mm Phillips.
  5. Lift the battery out of the Air.
    • Lift the battery out of the Air.
    • If you're installing a new battery, you should calibrate it after installation:
    • Charge it to 100%, and then keep charging it for at least 2 more hours. Then, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
  6. Remove the two small Phillips screws securing the logic board bracket to the upper case.
    • Remove the two small Phillips screws securing the logic board bracket to the upper case.
  7. Lift the logic board bracket out of the upper case.
    • Lift the logic board bracket out of the upper case.
  8. Use a spudger to pry trackpad control cable connector up off the logic board.
    • Use a spudger to pry trackpad control cable connector up off the logic board.
  9. Use the pointed end of a spudger to flip up the retaining flap on the trackpad control cable socket.
    • Use the pointed end of a spudger to flip up the retaining flap on the trackpad control cable socket.
  10. Peel the trackpad control cable off the adhesive securing it to the upper case. Pull the trackpad control cable out of its socket.
    • Peel the trackpad control cable off the adhesive securing it to the upper case.
    • Pull the trackpad control cable out of its socket.
Abschluss
4 weitere Nutzer haben diese Anleitung absolviert.
Hi, I was wondering if it's possible to remove the button pad on this model Air, and just install a regular trackpad like the ones in the Macbook Pro Unidbody's and up? Can someone let mek now if that is possible or do you need that click strip in order for it to function properly?
Jabran - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 22
Insgesamt: 19,933
