Zum Hauptinhalt wechseln
MacBook Core 2 Duo Heat Sink Replacement
Was du brauchst
  1. MacBook Core 2 Duo Heat Sink Replacement, Battery: Schritt 1, Bild 1 von 1
    • Use a coin or spudger to rotate the battery-locking screw 90 degrees clockwise.
    Frag FixBot
    Kommentar hinzufügen
  2. MacBook Core 2 Duo Heat Sink Replacement: Schritt 2, Bild 1 von 1
    • Lift the battery out of the computer.
    Frag FixBot
  3. MacBook Core 2 Duo Heat Sink Replacement, Memory Cover: Schritt 3, Bild 1 von 1
    • Unscrew the three evenly-spaced Phillips 000 screws from along the rear wall of the battery compartment.
    • The screws are captive to the metal memory cover so you cannot lose them.
    • Using The Flexible Extension sold by iFixit will help with this step.
    Frag FixBot
  4. MacBook Core 2 Duo Heat Sink Replacement: Schritt 4, Bild 1 von 1
    • Grasp the right end of the L-shaped memory cover, then pull it towards you so it clears the battery compartment opening.
    • Lift the memory cover up and out of the computer.
    Frag FixBot
  5. MacBook Core 2 Duo Heat Sink Replacement, Upper Case: Schritt 5, Bild 1 von 1
    • Remove the following 3 screws:
    • One 11 mm Phillips#00 in the middle of the lower case. (Head: 5mm dia. x .75mm thick)
    • Two 14.5 mm Phillips #00 (Head: 5mm dia. x .75mm thick)
    • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
    • The shorter of the three screws goes in the middle of the lower case.
    Frag FixBot
  6. MacBook Core 2 Duo Heat Sink Replacement: Schritt 6, Bild 1 von 1
    • Take extra caution with these screws as they can strip easily!
    • You could use a flexible extension to minimize stripping.
    • Remove the following 3 screws from the rear wall of the battery compartment:
    • One 3 mm Phillips #0. (Head: 2.75 mm. dia.)
    • Two 4 mm Phillips #0 on the either side. (Head: 2.75mm dia.)
    Frag FixBot
  7. MacBook Core 2 Duo Heat Sink Replacement: Schritt 7, Bild 1 von 1
    • Remove the two Phillips screws from either side of the right wall of the battery compartment (not the ones closest to the battery connector).
    • Two 6.25 mm Phillips #000. (Head: 4 mm. dia. x .5mm thick)
    Frag FixBot
  8. MacBook Core 2 Duo Heat Sink Replacement: Schritt 8, Bild 1 von 1
    • Remove the four indicated Phillips screws from the front wall of the battery compartment. When working from the left, remove the 2nd, 4th, 7th and 9th screws.
    • Four 3.25 mm Phillips #000. (Head: 4 mm. dia. x 4mm thick)
    Frag FixBot
  9. MacBook Core 2 Duo Heat Sink Replacement: Schritt 9, Bild 1 von 1
    • Remove the following 4 screws from the back of the computer:
    • Two 11 mm Phillips #00, with Shank (2.2mm dia. x 2 mm len.) (Head: 3.2 mm. dia. x .5mm thick)
    • Two 7.25 mm Phillips #00, with Shank (2mm dia. x 3.75 mm len.) (Head: 3.2 mm. dia. x .5mm thick)
    • During reassembly, the two longer screws go on the inside, and the two shorter screws go on the outside.
    Frag FixBot
  10. MacBook Core 2 Duo Heat Sink Replacement: Schritt 10, Bild 1 von 1
    • Remove the two Phillips screws from the optical drive (right) side of the computer:
    • Two 5.2 mm Phillips #00, with shank (2.3mm dia. x 3.25 mm len.) (Head: 3.2 mm. dia. x .5mm thick)
    • It is not necessary to remove the similar screws on the ports (left) side of the computer.
    Frag FixBot
  11. MacBook Core 2 Duo Heat Sink Replacement: Schritt 11, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Plastic Cards
    $2.99
    • There's a trackpad and keyboard ribbon cable connecting the upper case to the logic board, so don't pull the upper case off entirely just yet.
    • Use a plastic opening tool, an expired plastic credit, or a similarly-thick card to pry up on the upper case, starting in the upper-left corner and working around to the front of the computer.
    • The upper case is likely to stick at its connection above the front edge of the optical drive. If this happens, first free all other sides, then proceed to pull upward on the upper case from either side of the optical drive opening. Here again, inserting a plastic card, guitar pick, etc. can be useful.
    • If you stand the base of the MacBook on one end to get a better look, you may displace the four grey plastic clips that hold the right side of the upper case in place. Don't panic. They slide into slots at the top rightmost edge of the lower frame, above the front edge of the optical drive.
    • During reassembly, make sure the clips on the right side, above the optical drive, click firmly into place. They're different from the clips on the left side, and so normally they require a little firmer pressure to click into place.
    Frag FixBot
  12. MacBook Core 2 Duo Heat Sink Replacement: Schritt 12, Bild 1 von 3 MacBook Core 2 Duo Heat Sink Replacement: Schritt 12, Bild 2 von 3 MacBook Core 2 Duo Heat Sink Replacement: Schritt 12, Bild 3 von 3
    • While holding up the upper case, pull up the black tab on the connector end of the silver ribbon cable away from the connector's socket on the logic board.
    • If there is no black tab, you can also use a spudger to gently pry the connector out of its socket on the logic board. This connector is tall, so be sure to pry straight up.
    • If you happen to break your upper case cable when removing the upper case, we stock the cable individually and we have a guide that makes replacing it easy.
    • While you have the upper case removed, it's a good time to remove dust, hair, etc. It's best to use a can of compressed air, though if you use a brush, make sure that its bristles are made of a material (usually animal hair) that doesn't generate static electricity, which can destroy electronics.
    • Upon reassembly, there are 4 grey plastic clips installed in slots running along the top of the frame in front of the optical drive (refer to second and third pictures). These clips must be installed in their slots for their mating tabs on the underside of the right side of the upper case to snap into them.
    Frag FixBot
  13. MacBook Core 2 Duo Heat Sink Replacement, Heat Sink: Schritt 13, Bild 1 von 1
    • Carefully peel up the black felt tape between the heat sink and fan.
    Frag FixBot
  14. MacBook Core 2 Duo Heat Sink Replacement: Schritt 14, Bild 1 von 1
    • Peel up the small black rubber cover from the right side of the heat sink.
    Frag FixBot
  15. MacBook Core 2 Duo Heat Sink Replacement: Schritt 15, Bild 1 von 2 MacBook Core 2 Duo Heat Sink Replacement: Schritt 15, Bild 2 von 2
    • Use a spudger to disconnect the two newly-revealed temperature sensor connectors from the logic board.
    • If you have a MacBook Core 2 Duo Santa Rosa/Penryn, there is only one temperature sensor.
    Frag FixBot
  16. MacBook Core 2 Duo Heat Sink Replacement: Schritt 16, Bild 1 von 2 MacBook Core 2 Duo Heat Sink Replacement: Schritt 16, Bild 2 von 2
    • Remove the four Phillips screws securing the heat sink to the lower case.
    • Be sure to secure the ground loop for the speaker cable beneath the screw in the lower right corner when replacing the heat sink.
    • If you have a MacBook Core 2 Duo Santa Rosa/Penryn, the two Philips screws on the right are in a different location.
    Frag FixBot
  17. MacBook Core 2 Duo Heat Sink Replacement: Schritt 17, Bild 1 von 1
    • Lift the heat sink out of the computer, making sure the black tape doesn't catch on the heat sink.
    • If you need to mount the heat sink back into the laptop, we have a thermal paste guide that makes replacing the thermal compound easy.
    Frag FixBot
Abschluss
118 weitere Personen haben diese Anleitung absolviert.
7 Kommentare zur Anleitung
what if the black felt tape is dissolve itself in step 13? do i have to renew it or doesnt metter? it just crumbled.
laurids wiemer - Antwort Teilen
Hi.
I love these guides, they have helped me to replace the airport card, replace the keyboard cable and modify the optibay to install a 2nd drive.
The last 2 jobs I have completed were to remove the cooling fan to clean it and the exit of the heat sink and later to remove the heat sink to renew the thermal paste conducting material.
My suggestions would be if you are going to remove the heat sink take out the cooling fan first. This is just because the removal of the heat sink is much easier if the fan is out and it's really not too much more work and when you re-assemble make sure the black tape is really sticking down, if it's not the full cooling will be lost and funnily enough the noise of the fan increases.
Thanks ifixit team, you have been life savers.
respect
Martin Batho - Antwort Teilen
I used the guide and had no problems getting to the point of replacing the heatsink. I see how the rear heat sensor (250) clips onto the logic board but for the life of me, I cannot see how the longer sensor attaches. I see two contacts but other than the felt thing, there is no way to attach. . . What did I do wrong. . . HELP. Milt King
Milton King - Antwort Teilen
To refit the temperature sensors, ensure the cables are rooted under the clips of the heatsink. The connectors then just push down on to the motherboard pins.
Antony Gibson - Antwort Teilen
Question about part compatibility: the guide doesn’t show part number IF186-091-1.
Does this heatsink have sensors that need to be plugged in on the motherboard?
cubytus - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 12
Letzte 7 Tage: 29
Letzte 30 Tage: 139
Insgesamt: 141,412
