Einleitung
How to reach the logic board.
Ersatzteile
Keine Ersatzteile angegeben.
Use a coin or spudger to rotate the battery-locking screw 90 degrees clockwise.
Unscrew the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
Rotate the L-shaped memory cover so it clears the battery compartment opening and lift it up and out of the computer.
Remove the following 3 screws:
One 11 mm Phillips#00 in the middle of the case. (Head: 5mm dia. x .75mm thick)
Two 14.5 mm Phillips #00 (Head: 5mm dia. x .75mm thick)
Remove the following 3 screws from the rear wall of the battery compartment:
One 3 mm Phillips #0. (Head: 2.75 mm. dia.)
Two 4 mm Phillips #0 on the either side. (Head: 2.75mm dia.)
Remove the two Phillips screws from either side of the right wall of the battery compartment (not the ones closest to the battery connector).
Two 6.25 mm Phillips #000. (Head: 4 mm. dia. x .5mm thick)
Remove the four indicated Phillips screws from the front wall of the battery compartment. When working from the left, remove the 2nd, 4th, 7th and 9th screw.
Four 3.25 mm Phillips #000. (Head: 4 mm. dia. x 4mm thick)
Remove the following 4 screws from the back of the computer:
The longer screws go on the inside, shorter screws on the outside.
Two 11 mm Phillips #00, with Shank (2.2mm dia. x 2 mm len.) (Head: 3.2 mm. dia. x .5mm thick)
Two 7.25 mm Phillips #00, with Shank (2mm dia. x 3.75 mm len.) (Head: 3.2 mm. dia. x .5mm thick)
Remove the two Phillips screws from the optical drive side of the computer.
Two 5.2 mm Phillips #00, with Shank (2.3mm dia. x 3.5 mm len.) (Head: 3.2 mm. dia. x .5mm thick)
Starting near the display and working around to the front of the computer, pry up on the upper case. A plastic opening tool or a medium hard guitar pick may help you to do this.
While holding up the upper case, pull up the black tab of the silver cable away from its connector.
While you have the upper case removed, you may want to take the opportunity to remove dust, hair, etc. It's best to use a can of compressed air, though if you use a brush, make sure that its bristles are made of a material (usually animal hair) that doesn't generate static electricity, which can destroy electronics.
Disconnect the MagSafe board cable from the logic board by pulling the snap-in connector out (to the right).
Remove the single 9 mm Phillips screw securing the left speaker to the lower case.
Lift the left speaker out of its housing and set it to the side.
Two 7.5 mm Phillips from either end of the left I/O frame.
One 9 mm Phillips from the middle of the left I/O frame.
Remove the small black plastic spacer at the bottom of the left I/O frame.
Lift the left I/O frame up and out of the computer. Pay attention to the thin metal EMI fingers, as they may catch as you remove the left I/O frame.
Use a spudger to move the gray display data and black speaker cables to the right. This will reveal a silver screw securing the fan housing to the lower case.
Disconnect the black fan connector and two temperature sensor connectors from the logic board by pulling/prying them directly up.
Remove the following 6 screws:
One 3 mm Phillips on the right side of the fan.
One 6 mm Phillips on the left side of the fan.
Four 9 mm Phillips securing the heat sink to the lower case.
Hold the heat sink with one hand and the fan with your other hand, and lift the heat sink and fan assembly out of the computer. The fan is attached to the heat sink only with a strip of black felt tape, so be sure to remove both parts as a unit.
Disconnect the three antenna cables from the Airport card, and the black inverter cable from the logic board.
Remove the following 2 screws from the Airport card:
One 3 mm Phillips from the left side.
One 8 mm (with a large 2 mm head) Phillips from the right side.
Grasp the Airport card at its top and slide it toward the screen and out of the computer.
Use a spudger to disconnect the left speaker connector from the logic board.
Lift the left speaker out of the computer.
Disconnect the display data cable by pulling up on the black plastic pull-tab. If there is no pull-tab on the top of the connector, it may be helpful to use a spudger to disconnect this connector.
Use a spudger to disconnect the speaker connector and bluetooth connector from the logic board.
Use a spudger to carefully disconnect the microphone cable from the logic board. You'll want to work from side to side, and slowly wiggle the connector out of its socket.
Deroute the microphone cable from the silver metal clip just above the right RAM slot.
Use a spudger to carefully pry the battery connector up and disconnect it from the logic board.
Remove the three 3 mm Phillips screws securing the logic board to the lower case.
Lift the logic board up from the right side, and slide it up and out of the computer.
5 weitere Nutzer haben diese Anleitung absolviert.
