Einleitung
The hard drive cable also contains the IR sensor/sleep indicator.
Was du brauchst
Remove the following ten screws securing the lower case to the upper case:
Seven 3 mm Phillips screws.
Three 13.5 mm Phillips screws.
Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
Remove the lower case and set it aside.
In diesem Schritt verwendetes Werkzeug:P6 Pentalobe Screwdriver 2009 15" MacBook Pro Battery$5.49
Three Pentalobe screws secure the battery to the upper case. They can be removed with this special driver.
Remove the two exposed five-point Pentalobe screws along the top edge of the battery.
Use the tip of a spudger to bend back the finger of the "Warning: Do not remove the battery" sticker while you remove the five-point Pentalobe screw hidden underneath.
Lift the battery by its plastic pull tab and slide it away from the long edge of the upper case.
Tilt the battery back enough to access the battery cable connector.
Pull the battery cable connector away from its socket on the logic board and remove the battery from the upper case.
Remove two Phillips screws securing the hard drive bracket to the upper case.
Lift the the retaining bracket out of the upper case.
Lift the hard drive by its pull tab and pull it out of the chassis, minding the cable attaching it to the computer.
Remove the hard drive cable by pulling its connector straight away from the hard drive.
Remove the following four screws securing the hard drive and IR sensor cable to the upper case:
Two 1.5 mm Phillips screws.
Two 4 mm Phillips screws.
Slide the hard drive and IR sensor bracket away from the edge of the upper case.
Carefully peel the hard drive and IR sensor cable from the upper case.
Use the flat end of a spudger to pry the hard drive cable connector up off the logic board.
Lift the hard drive and IR sensor assembly out of the upper case.
Use the tip of a spudger to flip the ZIF connector on the hard drive cable.
Gently pull the sensor bracket cable out of the ZIF connector.
Use the flat end of a spudger to pry the hard drive cable up off the sensor bracket.
54 weitere Nutzer:innen haben diese Anleitung absolviert.
