Einleitung
Use this guide to replace the hard drive bracket nearest the front edge of the MacBook Pro 17" Unibody.
Was du brauchst
Remove the following ten screws securing the lower case to the upper case:
Three 13.5 mm Phillips screws.
Seven 3 mm Phillips screws.
Wedge your fingers between the lower case and the vent, and lift upward to release the two clips holding the lower case to the upper case.
Remove the lower case.
If present, grab the plastic tab attached to the battery connector and pull it toward the front edge of the device. For Late-2011 models the battery connector will not have a tab and is simply a plug that inserts straight down into the motherboard--to remove pry the plug straight up.
Remove the two Phillips screws securing the hard drive bracket to the upper case.
Pull the hard drive connector away from the body of the hard drive.
Remove the hard drive from your MacBook Pro.
Remove the two 5 mm Phillips #00 screws securing the hard drive bracket to the upper case.
Tilt the outer hard drive bracket up toward the logic board and remove it from the rear case.
10 weitere Nutzer:innen haben diese Anleitung absolviert.
