Zum Hauptinhalt wechseln
MacBook Unibody Model A1278 Hard Drive Bracket with Sleep Sensor Replacement
Was du brauchst
  1. MacBook Unibody Model A1278 Hard Drive Bracket with Sleep Sensor Replacement, Access Door: Schritt 1, Bild 1 von 1
    • With the case closed, place the Unibody top-side down on a flat surface.
    • Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
  2. MacBook Unibody Model A1278 Hard Drive Bracket with Sleep Sensor Replacement: Schritt 2, Bild 1 von 1
    • The access door should now be raised enough to lift it up and out of the Unibody.
  3. MacBook Unibody Model A1278 Hard Drive Bracket with Sleep Sensor Replacement, Battery: Schritt 3, Bild 1 von 1
    • Be sure the access door release latch is vertical before proceeding.
    • Grab the white plastic tab and pull the battery up and out of the Unibody.
  4. MacBook Unibody Model A1278 Hard Drive Bracket with Sleep Sensor Replacement, Lower Case: Schritt 4, Bild 1 von 1
    • Remove the following eight screws securing the lower case to the chassis:
    • One 3 mm Phillips screw.
    • Four 3.5 mm Phillips screws.
  5. MacBook Unibody Model A1278 Hard Drive Bracket with Sleep Sensor Replacement: Schritt 5, Bild 1 von 1
    • Using both hands, lift and remove the lower case off the upper case.
  6. MacBook Unibody Model A1278 Hard Drive Bracket with Sleep Sensor Replacement, Optical Drive: Schritt 6, Bild 1 von 1
    • Using the flat end of a spudger, pry the subwoofer connector straight up off the logic board.
    • On some models, the subwoofer connector is soldered to the logic board and will break if you pry it off. If you need to replace the speaker/subwoofer, you can pull back the foam padding on the connector and remove the red and black wires to disconnect. You will need to reinsert the wires from the new speaker to reconnect.
    • If you are only removing the optical drive and not replacing the speaker/subwoofer, you do not need to disconnect this connector.
  7. MacBook Unibody Model A1278 Hard Drive Bracket with Sleep Sensor Replacement: Schritt 7, Bild 1 von 1
    • Disconnect the camera cable by pulling the male end straight away from its socket.
  8. MacBook Unibody Model A1278 Hard Drive Bracket with Sleep Sensor Replacement: Schritt 8, Bild 1 von 1
    • Use a spudger to pry the optical drive connector straight up off the logic board.
  9. MacBook Unibody Model A1278 Hard Drive Bracket with Sleep Sensor Replacement: Schritt 9, Bild 1 von 1
    • Remove the two Phillips screws securing the subwoofer to the upper case.
    • The longer of the two screws is on the right.
  10. MacBook Unibody Model A1278 Hard Drive Bracket with Sleep Sensor Replacement: Schritt 10, Bild 1 von 1
    • The subwoofer is still connected to the right speaker, so don't completely remove it just yet.
    • Lift the subwoofer off the optical drive, and set it above the computer.
  11. MacBook Unibody Model A1278 Hard Drive Bracket with Sleep Sensor Replacement: Schritt 11, Bild 1 von 1
    • Remove the two Phillips screws securing the camera cable bracket to the upper case.
    • The leftmost screw may remain captive in the camera cable.
  12. MacBook Unibody Model A1278 Hard Drive Bracket with Sleep Sensor Replacement: Schritt 12, Bild 1 von 1
    • Remove the three 2.5 mm Phillips screws securing the optical drive to the upper case.
  13. MacBook Unibody Model A1278 Hard Drive Bracket with Sleep Sensor Replacement: Schritt 13, Bild 1 von 1
    • Lift the optical drive from its right edge and pull it out of the computer.
    • The hard drive cable may become disconnected from the logic board when removing the optical drive. Ensure it is connected during reassembly.
  14. MacBook Unibody Model A1278 Hard Drive Bracket with Sleep Sensor Replacement, Hard Drive Cable: Schritt 14, Bild 1 von 1
    • Remove the single Phillips screw securing the hard drive bracket to the upper case.
    • This screw is captive in the hard drive bracket.
  15. MacBook Unibody Model A1278 Hard Drive Bracket with Sleep Sensor Replacement: Schritt 15, Bild 1 von 1
    • Lift the hard drive by its plastic pull tab and remove the freed hard drive bracket.
  16. MacBook Unibody Model A1278 Hard Drive Bracket with Sleep Sensor Replacement: Schritt 16, Bild 1 von 1
    • Lift the hard drive out of its supports and disconnect the SATA cable by pulling the connector straight away from the hard drive.
  17. MacBook Unibody Model A1278 Hard Drive Bracket with Sleep Sensor Replacement: Schritt 17, Bild 1 von 1
    • Remove the four 10.3 mm Phillips screws securing the mid wall to the upper case.
  18. MacBook Unibody Model A1278 Hard Drive Bracket with Sleep Sensor Replacement: Schritt 18, Bild 1 von 1
    • Lift the mid wall out of the upper case.
  19. MacBook Unibody Model A1278 Hard Drive Bracket with Sleep Sensor Replacement: Schritt 19, Bild 1 von 1
    • Use a spudger to pry the hard drive cable connector straight up off the logic board.
  20. MacBook Unibody Model A1278 Hard Drive Bracket with Sleep Sensor Replacement: Schritt 20, Bild 1 von 2 MacBook Unibody Model A1278 Hard Drive Bracket with Sleep Sensor Replacement: Schritt 20, Bild 2 von 2
    • Peel the hard drive cable from the adhesive securing it to the upper case, and maneuver the plastic retaining block out of the upper case.
    • During reassembly, be sure the two pins on top of the plastic retaining block mate to the holes on the underside of the midwall.
  21. MacBook Unibody Model A1278 Hard Drive Bracket with Sleep Sensor Replacement, Hard Drive Bracket with Sleep Sensor: Schritt 21, Bild 1 von 2 MacBook Unibody Model A1278 Hard Drive Bracket with Sleep Sensor Replacement, Hard Drive Bracket with Sleep Sensor: Schritt 21, Bild 2 von 2
    • Use the pointed end of a spudger to flip the lock on the ZIF connector.
  22. MacBook Unibody Model A1278 Hard Drive Bracket with Sleep Sensor Replacement: Schritt 22, Bild 1 von 2 MacBook Unibody Model A1278 Hard Drive Bracket with Sleep Sensor Replacement: Schritt 22, Bild 2 von 2
    • Pull the hard drive bracket cable out of its socket.
  23. MacBook Unibody Model A1278 Hard Drive Bracket with Sleep Sensor Replacement: Schritt 23, Bild 1 von 3 MacBook Unibody Model A1278 Hard Drive Bracket with Sleep Sensor Replacement: Schritt 23, Bild 2 von 3 MacBook Unibody Model A1278 Hard Drive Bracket with Sleep Sensor Replacement: Schritt 23, Bild 3 von 3
    • Peel the connector side of the sleep sensor cable up from the adhesive securing it to the upper case.
    • Be especially careful peeling the folded section of the cable, as this is area will be more easily damaged.
  24. MacBook Unibody Model A1278 Hard Drive Bracket with Sleep Sensor Replacement: Schritt 24, Bild 1 von 1
    • Remove the two 5 mm Phillips #00 screws securing the hard drive bracket to the upper case.
  25. MacBook Unibody Model A1278 Hard Drive Bracket with Sleep Sensor Replacement: Schritt 25, Bild 1 von 2 MacBook Unibody Model A1278 Hard Drive Bracket with Sleep Sensor Replacement: Schritt 25, Bild 2 von 2
    • Insert the tip of a spudger between the hard drive bracket and the front edge of the upper case to free it from its recess.
  26. MacBook Unibody Model A1278 Hard Drive Bracket with Sleep Sensor Replacement: Schritt 26, Bild 1 von 2 MacBook Unibody Model A1278 Hard Drive Bracket with Sleep Sensor Replacement: Schritt 26, Bild 2 von 2
    • Pull the hard drive bracket and sleep sensor assembly out from the recess in the upper case.
    • Remove the bracket slowly and carefully to ensure you do not rip the sleep sensor cable, which may still be adhered to the upper case.
  27. MacBook Unibody Model A1278 Hard Drive Bracket with Sleep Sensor Replacement: Schritt 27, Bild 1 von 1
    • After ensuring the cable is freed of all adhesive, remove the hard drive bracket and sleep sensor assembly from the upper case.
    • If your new bracket cable is not pre-folded, use the old one as a guide to crease it for proper fit in your MacBook.
Abschluss
8 weitere Personen haben diese Anleitung absolviert.
Sam Goldheart
475.825 Reputation
538 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
123 Mitglieder
24.065 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 22
Letzte 30 Tage: 69
Insgesamt: 8,904
