Einleitung
This is a prerequisite guide to explain how to expose the internal components of the Magic Bullet NutriBullet Pro. To determine what is wrong with your Nutribullet follow this link to the troubleshooting guide.
Was du brauchst
To start the disassembly of the Magic Bullet NutriBullet Pro you will begin from the bottom.
Flip the device over to the bottom.
Unscrew the four 1 cm screws using #2 Phillips Head Screwdriver.
Remove the loose bottom portion of the device by pulling up from the bottom.
Unscrew the two 1 cm screws holding down the power cord using the #2 Phillips Head Screwdriver.
Unscrew the three 1 cm screws on the device circled on the screws pictures using the #1 Philips Head Screwdriver.
Lift off the grey plastic piece off.
Slide off the silver metal piece.
Flip the device over.
Remove the three rubber seals covering the screws by pulling the components upward with the tweezer.
Unscrew the three 16 mm screws using the #2 Phillips Head Screwdriver.
2 weitere Personen haben diese Anleitung absolviert.
