Einleitung
The main board needs to be partially removed for several of the steps, so completely removing and replacing it isn't too much more work. This should be done as a last resort if nothing else works when fixing the iP37.
Was du brauchst
Pry the exterior housing off the iHome iP37. You may need extra leverage to do this.
Remove these four 9 mm screws from the plastic casing; you will need a Phillips #2 driver to do this.
Remove the flanged 9 mm screw from the counterweight; you will need a Phillips #2 driver to do this.
Lift and remove the counterweight.
Remove the two 9 mm screws that hold the main printed circuit board onto the rest of the iP37; you will need a Phillips #2 driver to do this.
Slowly lift the PCB away from the rest of the device
Remove the ribbon by first removing the brown insert piece from the connector on the button board
Pull the ribbon out of the connector on the button board by the blue tab.
Peel away the tape holding down the wires between the main board and the DC power and 3.5 mm audio jack board.
Remove the black tape holding down the four wires connecting the main board to the upper half of the device.
Carefully peel away the black melted plastic that covers the connection points from the four wires to the main board.
Desolder the two red and two black wires from the main board, which will completely free the main board from the rest of the assembly.
