Was du brauchst
Carefully lift the back plate off the watch. You will notice a lithium battery and rubber gasket attached to the back plate.
Using the plastic removal tool, pry the battery from the backing plate. The battery is simply attached with glue.
Desolder the battery connections from the motherboard. Learn how to solder components here!
Locate the ribbon connection, and use remove the clips holding the strip on each side using needle tool.
With a pair of tweezers, carefully remove the ribbon strip connection.
Place a small flat head screwdriver under the LED screen, and carefully push it out of it's socket.
Remove final connection to accelerometer. The LED screen is now separated from the device.
