Einleitung
How to access and remove the motherboard of the Martian Smartwatch
Was du brauchst
Carefully lift the back plate off the watch. You will notice a lithium battery and rubber gasket attached to the back plate.
Using the plastic removal tool, pry the battery from the backing plate. The battery is simply attached with glue.
Desolder the battery connections from the motherboard. Learn how to solder components here!
Use ESD safe tweezers to remove the gold ribbon cable.
This will expose a second 5.2mm Phillips head screw that can be removed with a PH00 screwdriver.
Use a spudger to gently pry on the motherboard towards the top of the watch, being towards the 12 o'clock position to loosen the motherboard.
You can now access the parts and pieces on the bottom of, and below the motherboard.
