Zum Hauptinhalt wechseln
Master and Dynamic MW50 Charging Port Replacement
Was du brauchst
  1. Master and Dynamic MW50 Charging Port Replacement, Master and Dynamic MW50 Disassembly: Schritt 1, Bild 1 von 3 Master and Dynamic MW50 Charging Port Replacement, Master and Dynamic MW50 Disassembly: Schritt 1, Bild 2 von 3 Master and Dynamic MW50 Charging Port Replacement, Master and Dynamic MW50 Disassembly: Schritt 1, Bild 3 von 3
    • Pull the cushion off of the desired side by gripping the top of the headphones and pulling the cushion off.
  2. Master and Dynamic MW50 Charging Port Replacement: Schritt 2, Bild 1 von 1
    • Remove the four 5mm screws from the earpiece with a Y1 Triwing screwdriver.
  3. Master and Dynamic MW50 Charging Port Replacement: Schritt 3, Bild 1 von 1
    • Use the Jimmy to lift up the black cover to get inside the device.
  4. Master and Dynamic MW50 Charging Port Replacement, Charging Port: Schritt 4, Bild 1 von 2 Master and Dynamic MW50 Charging Port Replacement, Charging Port: Schritt 4, Bild 2 von 2
    • Remove the two 2mm screws pictured with a JIS #00 screwdriver.
    • Gently pull the silver cover off of the ear piece.
  5. Master and Dynamic MW50 Charging Port Replacement: Schritt 5, Bild 1 von 1
    • Remove the two 2mm screws shown with a JIS #00 screwdriver.
  6. Master and Dynamic MW50 Charging Port Replacement: Schritt 6, Bild 1 von 1
    • Lift up the mother board with the attached charging port to see the soldering points. You must desolder these points in order to detach (and re-attach) the charging port.
Abschluss
Tyler Guffey
208 Reputation
2 Anleitungen geschrieben
Cal Poly, Team S1-G4, White Winter 2019 Mitglied von Cal Poly, Team S1-G4, White Winter 2019
CPSU-WHITE-W19S1G4
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 7
Insgesamt: 318
