Zum Hauptinhalt wechseln
Master and Dynamic MW50 Motherboard Replacement
Was du brauchst
  1. Master and Dynamic MW50 Motherboard Replacement, Master and Dynamic MW50 Disassembly: Schritt 1, Bild 1 von 3 Master and Dynamic MW50 Motherboard Replacement, Master and Dynamic MW50 Disassembly: Schritt 1, Bild 2 von 3 Master and Dynamic MW50 Motherboard Replacement, Master and Dynamic MW50 Disassembly: Schritt 1, Bild 3 von 3
    • Pull the cushion off of the desired side by gripping the top of the headphones and pulling the cushion off.
  2. Master and Dynamic MW50 Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Remove the four 5mm screws from the earpiece with a Y1 Triwing screwdriver.
  3. Master and Dynamic MW50 Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Use the Jimmy to lift up the black cover to get inside the device.
  4. Master and Dynamic MW50 Motherboard Replacement, Motherboard: Schritt 4, Bild 1 von 3 Master and Dynamic MW50 Motherboard Replacement, Motherboard: Schritt 4, Bild 2 von 3 Master and Dynamic MW50 Motherboard Replacement, Motherboard: Schritt 4, Bild 3 von 3
    • Remove the 2mm screw holding the side cover plate in place with a JIS #00 screwdriver.
    • Move the side cover off to the side.
    • The black cable connected to the motherboard from the side cover can be gently pulled off from the motherboard side. It isn't soldered on.
  5. Master and Dynamic MW50 Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Desolder all the wires connected to the motherboard.
    • Refer to this picture for soldering the wires on the new motherboard.
  6. Master and Dynamic MW50 Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Remove the two 2mm screws holding the motherboard in place.
  7. Master and Dynamic MW50 Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Replace with new motherboard.
Abschluss
To reassemble your device, follow these instructions in reverse order. You may want to use the picture from Step 5 to correctly re-solder your device.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ryan Chan
297 Reputation
2 Anleitungen geschrieben
Cal Poly, Team S1-G4, White Winter 2019 Mitglied von Cal Poly, Team S1-G4, White Winter 2019
CPSU-WHITE-W19S1G4
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 15
Insgesamt: 331
