Zum Hauptinhalt wechseln
Master and Dynamic MW50 Right/Left Speaker Replacement
Was du brauchst
  1. Master and Dynamic MW50 Right/Left Speaker Replacement, Master and Dynamic MW50 Disassembly: Schritt 1, Bild 1 von 3 Master and Dynamic MW50 Right/Left Speaker Replacement, Master and Dynamic MW50 Disassembly: Schritt 1, Bild 2 von 3 Master and Dynamic MW50 Right/Left Speaker Replacement, Master and Dynamic MW50 Disassembly: Schritt 1, Bild 3 von 3
    • Pull the cushion off of the desired side by gripping the top of the headphones and pulling the cushion off.
  2. Master and Dynamic MW50 Right/Left Speaker Replacement: Schritt 2, Bild 1 von 1
    • Remove the four 5mm screws from the earpiece with a Y1 Triwing screwdriver.
  3. Master and Dynamic MW50 Right/Left Speaker Replacement: Schritt 3, Bild 1 von 1
    • Use the Jimmy to lift up the black cover to get inside the device.
  4. Master and Dynamic MW50 Right/Left Speaker Replacement, Right/Left Speaker: Schritt 4, Bild 1 von 1
    • Desolder the two wires connected to the speaker.
  5. Master and Dynamic MW50 Right/Left Speaker Replacement: Schritt 5, Bild 1 von 1
    • Use a heating gun to remove the glue from the speaker.
    • Once the glue is removed, gently pull out the speaker.
Abschluss
Katie Dunnigan
85 Reputation
1 Anleitung geschrieben
Cal Poly, Team S1-G4, White Winter 2019 Mitglied von Cal Poly, Team S1-G4, White Winter 2019
CPSU-WHITE-W19S1G4
4 Mitglieder
12 Anleitungen geschrieben
Ein Kommentar
This is awesome but Master & Dynamic don’t sell replacement 45mm 32 ohm drivers and won’t share the specs.
If anyone know where to get a replacement which will work well with these headphones please share!!!
paul
bloodygoose@icloud.com
psullivan_au - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 11
Insgesamt: 675
