Einleitung
If your speaker is not producing sound correctly, it may be necessary to replace the speaker component. This guide will show the five steps for removing the speaker. Soldering is required for this replacement, If you don't know how to solder or desolder, click here for a great guide.
Was du brauchst
Pull the cushion off of the desired side by gripping the top of the headphones and pulling the cushion off.
Use a heating gun to remove the glue from the speaker.
Once the glue is removed, gently pull out the speaker.
Ein Kommentar
This is awesome but Master & Dynamic don’t sell replacement 45mm 32 ohm drivers and won’t share the specs.
If anyone know where to get a replacement which will work well with these headphones please share!!!
paul
bloodygoose@icloud.com
