Zum Hauptinhalt wechseln
Memorex CD Alarm Clock Radio Antenna Replacement
Was du brauchst
  1. Memorex CD Alarm Clock Radio Antenna Replacement, Memorex CD Alarm Clock Radio: Schritt 1, Bild 1 von 3 Memorex CD Alarm Clock Radio Antenna Replacement, Memorex CD Alarm Clock Radio: Schritt 1, Bild 2 von 3 Memorex CD Alarm Clock Radio Antenna Replacement, Memorex CD Alarm Clock Radio: Schritt 1, Bild 3 von 3
    • Turn the clock radio over so the bottom is facing up.
    • Pull the tab upward and remove the cover from the battery compartment.
    • Remove the batteries.
  2. Memorex CD Alarm Clock Radio Antenna Replacement: Schritt 2, Bild 1 von 3 Memorex CD Alarm Clock Radio Antenna Replacement: Schritt 2, Bild 2 von 3 Memorex CD Alarm Clock Radio Antenna Replacement: Schritt 2, Bild 3 von 3
    • Remove the five screws on the bottom of the device with a screwdriver.
    • Grasp the top and bottom and gently pull apart.
  3. Memorex CD Alarm Clock Radio Antenna Replacement, Antenna: Schritt 3, Bild 1 von 1
    • Locate the small silver transistor between the front left speaker and the tuning knob. The antenna should be attached directly below the transistor.
    • Deolder the antenna wire from the circuit board, and remove the wire.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 800
