Zum Hauptinhalt wechseln
Memorex Mi3X Minimove Radio Replacement
Was du brauchst
  1. Memorex Mi3X Minimove Radio Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Remove the two plastic screw covers on the back of your Minimove by inserting the flat end of your plastic opening tool between the screw cover and the back panel and prying it out.
    • It may be helpful to pull the plastic covers out with your fingers once the top of the cover has been revealed by using the plastic opening tool.
  2. Memorex Mi3X Minimove Radio Replacement: Schritt 2, Bild 1 von 1
    • This step will require at least a 30 mm Phillips #1 screwdriver.
    • Use a Phillips #1 screwdriver to remove the two 12 mm screws.
  3. Memorex Mi3X Minimove Radio Replacement: Schritt 3, Bild 1 von 1
    • The bottom panel screws and screw covers must be removed in order to access the back panel.
    • Remove the four grey screw covers by inserting the plastic opening tool underneath the screw covers and rotating around the circumference.
    • The adhesive on the screw covers should be sticky enough to put the covers back on when re-assembling the device.
  4. Memorex Mi3X Minimove Radio Replacement: Schritt 4, Bild 1 von 1
    • Remove the two 8 mm screws with a Phillips #1 screwdriver.
    • Remove the two 12 mm screws with a long Phillips #1 screwdriver.
  5. Memorex Mi3X Minimove Radio Replacement: Schritt 5, Bild 1 von 2 Memorex Mi3X Minimove Radio Replacement: Schritt 5, Bild 2 von 2
    • To remove the back panel, use the plastic opening tool and gently work around the outline of the panel. The outline wraps around the sides and can be spotted at the top back of the device.
  6. Memorex Mi3X Minimove Radio Replacement: Schritt 6, Bild 1 von 3 Memorex Mi3X Minimove Radio Replacement: Schritt 6, Bild 2 von 3 Memorex Mi3X Minimove Radio Replacement: Schritt 6, Bild 3 von 3
    • Be careful not to use too much force to remove the panel. The antenna wire is connected to the inside of the panel and may be damaged or ripped off if the panel is not gently removed.
    • After loosening the panel with the plastic opening tool, use moderate force to pry open the panel with your hands.
    • Carefully pull the panel off.
  7. Memorex Mi3X Minimove Radio Replacement: Schritt 7, Bild 1 von 1
    • Use a Phillips #1 screwdriver to detach the wire from the back panel by removing the 8 mm screw connecting the wire to the antenna.
  8. Memorex Mi3X Minimove Radio Replacement: Schritt 8, Bild 1 von 2 Memorex Mi3X Minimove Radio Replacement: Schritt 8, Bild 2 von 2
    • If desired, the antenna can now be removed by pulling inwards and horizontal to the panel bottom.
  9. Memorex Mi3X Minimove Radio Replacement: Schritt 9, Bild 1 von 1
    • Use the Phillips #1 screwdriver to remove the four 12 mm screws.
    • Remove the five 6 mm screws at the top with the same screwdriver.
  10. Memorex Mi3X Minimove Radio Replacement: Schritt 10, Bild 1 von 1
    • Use a Phillips #1 screwdriver and remove the two vertical 8 mm screws from the top.
  11. Memorex Mi3X Minimove Radio Replacement: Schritt 11, Bild 1 von 2 Memorex Mi3X Minimove Radio Replacement: Schritt 11, Bild 2 von 2
    • Pry open the inner back panel by inserting the plastic opening tool in the crack at the top corner.
    • Use moderate force to pry it open and take the cover off.
  12. Memorex Mi3X Minimove Radio Replacement, Radio: Schritt 12, Bild 1 von 2 Memorex Mi3X Minimove Radio Replacement, Radio: Schritt 12, Bild 2 von 2
    • A plastic sheet is in between the radio motherboard (the upper brown board) and the audio port daughterboard (the lower green board) coming from the right speaker housing. Be careful when removing the back panel as to not damage the boards.
    • Remove the bottom panel of the boombox by carefully pulling the panel straight backwards from the boombox until the boards are free.
  13. Memorex Mi3X Minimove Radio Replacement: Schritt 13, Bild 1 von 3 Memorex Mi3X Minimove Radio Replacement: Schritt 13, Bild 2 von 3 Memorex Mi3X Minimove Radio Replacement: Schritt 13, Bild 3 von 3
    • Pull out the 5 white pinhead connectors using an IC (Integrated Circuit) extractor. Pinch the IC extractor just under the top lip of the wire housing. There are two 10 pin connectors, one 8 pin connector, one 7 pin connector, and one 2 pin connector.
    • When reassembling, there is only one way to reinsert the pinhead connectors. Make sure the orientation matches that of the receiving connector on the motherboard.
  14. Memorex Mi3X Minimove Radio Replacement: Schritt 14, Bild 1 von 2 Memorex Mi3X Minimove Radio Replacement: Schritt 14, Bild 2 von 2
    • Use the Phillips #1 screwdriver to remove the three 8 mm screws holding the motherboard in place.
  15. Memorex Mi3X Minimove Radio Replacement: Schritt 15, Bild 1 von 2 Memorex Mi3X Minimove Radio Replacement: Schritt 15, Bild 2 von 2
    • Detach the smaller green audio port daughterboard by removing the two 8 mm screws with a Phillips #1 screwdriver.
  16. Memorex Mi3X Minimove Radio Replacement: Schritt 16, Bild 1 von 2 Memorex Mi3X Minimove Radio Replacement: Schritt 16, Bild 2 von 2
    • Detach the black ground wire by desoldering it from the inner case.
    • Visit the soldering guide for help with desoldering.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 2-9, Amido Winter 2014 Mitglied von Cal Poly, Team 2-9, Amido Winter 2014
CPSU-AMIDO-W14S2G9
5 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 12
Insgesamt: 415
